How to use RG520N QuecOpen QMAP API
This video shows how to use the QMAP API.
0:17~0:20: List QMAP General Configuration API
0:22~0:27: List QMAP LAN Configuration API
0:30~0:33: List QMAP WAN Configuration API
You can refer to Quectel_RG520N_Series_QuecOpen_QMAP_Interface_Usage_Reference_Manual_V1.0.0_Preliminary to check detail information about each QMAP API.
[0:35~1:45] How to use qmap_test command (QMAP API) in AP Linux to establish data call in router mode.
0:38~0:57: Check WWAN profile, PDN to VLAN mapping table, and VLAN ID 0 router mode.
1:00~1:09: Use wwan_handle 1 (APN 1) to dial data call.
1:12~1:29: Confirm wwan_profile 1 dial successfully and check related interfaces in AP Linux and ETH PC.
1:30~1:45: Check if PC can ping to the Internet in IP based and DNS based.
[1:46~3:08] How to use qmap_test command (QMAP API) in AP Linux to establish data call in IPPT (IP Passthrough) mode.
1:46~2:27: Set VLAN ID 0 to IPPT adaptive mode.
2:28~2:38: Use wwan_handle 1 (APN 1) to dial data call.
2:39~2:54: Confirm wwan_profile 1 dial successfully and check related interfaces in AP Linux and ETH PC.
2:55~3:08: Check if PC can ping to the Internet in IP based and DNS based.
[3:09~5:20] How to use qmap_test command (QMAP API) in AP Linux to establish data call in multiple PDN VLAN with with router mode.
3:09~3:43: Add VLAN (ID 2) interface with IPA offload. Module will reboot automatically to take effect for adding first VLAN.
3:44~3:59: Confirm VLAN added successfully and check VLAN ID 0 and VLAN ID 2 are in router mode.
4:00~4:25: Add new WWAN profile. Map wwan_handle with corresponding VLAN ID.
4:26~4:38: Use wwan_handle 1 (APN 1) and wwan_handle 2 (APN2) to dial data call.
4:39~5:07: Confirm VLAN and bridge interfaces are existed. check related interfaces in AP Linux and ETH PC.
5:08~5:20: Check if PC can ping to the Internet in IP based and DNS based.
[5:21~7:34] How to use qmap_test command (QMAP API) in AP Linux to establish data call in multiple PDN VLAN with IPPT (IP Passthrough) mode.
5:21~5:48: Add VLAN (ID 2) interface with IPA offload. Module will reboot automatically to take effect for adding first VLAN.
5:49~6:12: Confirm VLAN added successfully. Set VLAN ID 0 and VLAN ID 2 to IPPT adaptive mode.
6:13~6:29: Add new WWAN profile and Map wwan_handle with corresponding VLAN ID.
6:30~6:44: Use wwan_handle 1 (APN 1) and wwan_handle 2 (APN2) to dial data call.
6:45~6:54: Confirm VLAN and bridge interfaces are existed. check related interfaces in AP Linux and ETH PC.
6:55~7:07: Confirm public IP of wwan_handle 1 with APN 1 pass through to PC’s ethernet interface with VLAN ID 0.
7:08~7:19: Confirm public IP of wwan_handle 2 with APN 2 pass through to PC’s ethernet interface with VLAN ID 2.
7:20~7:34: Check if PC can ping to the Internet in IP based and DNS based.
