Hey there,
How we can use FCM360W AT commands in Linux environment. In windows i have use QCom tool to send AT commands and its working perfectly but its have many differences in Linux environment (Ubuntu) . also I’m using USB to UART to cable connect with my pc.
oh thank you the reason is in my project i have to connect the module using UART and i have to write a program in C to initiate AT commands in Linux environment. isn’t it not going to work?
It should work with standard Linux driver, until it is some newer revision of the adapter.
All my current adapters are based on other chips, so I cannot check the driver.
