Hi there,
I want to use fast timer with MC60 opencpu. I don’t have any problem with stack timer. I had used stack stack timer without any problem at all. I am facing issue with fast timer.
If I am using this ret=RIL_GPS_Read(“ALL”,rdBuff); in timer handler it is restarting the module after first run.
However, it is not restarting if I remove ret=RIL_GPS_Read(“ALL”,rdBuff); from timer handler.
Interval is 10 seconds
//register a timer
ret = Ql_Timer_RegisterFast(GP_timer, Timer_handler, &m_param1);
if(ret <0)
APP_DEBUG("\r\n<--failed!!, Ql_Timer_Register: timer(%d) fail ,ret = %d -->\r\n",GP_timer,ret);
APP_DEBUG("\r\n<--Register: timerId=%d, param = %d,ret = %d -->\r\n", GP_timer ,m_param1,ret);
//start a timer,repeat=true;
ret = Ql_Timer_Start(GP_timer,GPT_Interval,TRUE);
if(ret < 0)
APP_DEBUG("\r\n<--failed!! GP timer Ql_Timer_Start ret=%d-->\r\n",ret);
APP_DEBUG("\r\n<--GP timer Ql_Timer_Start(ID=%d,Interval=%d,) ret=%d-->\r\n",GP_timer,GPT_Interval,ret);
Timer handler callback:
if(GP_timer == timerId)
s32 ret=-1;
u8 rd_buff[1000];
APP_DEBUG("<-- GP-Timer_handler, param:%d -->\r\n", *((s32*)param));
ret = RIL_GPS_Read("RMC",rd_buff);
APP_DEBUG("GPS READ %s\r\n",rd_buff);
//not repeat
// Ql_sprintf(tx_buffer,"Data ID = %d ", *((s32*)param));
// GPRS_SendData(tx_buffer);
Looking forward how can we run fast timer in free running mode.
Any help will be appreciated. Thank you
