How to start camera in SMART-EVB-G5 kit with IOT module SC206E-EM
Hi everyone
I wants to start front camera(J0402) in SMART-EVB-G5 kit with module SC206E-EM.
I added default linux image and trying to start camera using gst-launch command.
I use below command.
$ gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! autovideosink
When I apply this command I got below error.
root@qrbx210-rbx:~# gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! autovideosink
(gst-plugin-scanner:2528): GLib-GObject-CRITICAL **: 08:01:45.396: g_param_spec_internal: assertion '!(flags & G_PARAM_STATIC_NAME) || is_canonical (name)' failed
[   99.432947] msm_vidc:   high: 00000001: ....d: Opening video instance: 0000000000000000, 1
[   99.443703] msm_vidc:   high: 00000001: ....d: Closed video instance: 0000000000000000
[   99.451768] msm_vidc:   high: 00000001: ....e: Opening video instance: 0000000000000000, 0
[   99.461959] msm_vidc:   high: 00000001: ....e: Closed video instance: 0000000000000000
[   99.470007] CAM_ERR: CAM-CPAS: cam_cpas_subdev_ioctl: 749 Invalid command -2140645888 for CPAS!
[   99.479049] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-isp
[   99.487700] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[   99.496114] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[   99.504447] CAM_ERR: CAM-ACTUATOR: cam_actuator_subdev_ioctl: 68 Invalid ioctl cmd: 2154321408
[   99.513390] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[   99.522158] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[   99.530908] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[   99.539628] CAM_ERR: CAM-FLASH: cam_flash_subdev_ioctl: 309 Invalid ioctl cmd type
[   99.547495] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-ope
[   99.556250] CAM_INFO: CAM-SMMU: cam_smmu_need_force_alloc_cached: 383 force_cache_allocs=0
[   99.565087] CAM_WARN: CAM-CRM: cam_req_mgr_close: 195 release invoked associated userspace process has died, open_cnt: 1
[   99.576175] CAM_WARN: CAM-CPAS: __cam_cpas_subdev_close: 706 device already closed, open_cnt: 0
[   99.812185] msm_vidc:   high: 00000001: ....d: Opening video instance: 0000000000000000, 1
[   99.822533] msm_vidc:   high: 00000001: ....d: Closed video instance: 0000000000000000
[   99.830592] msm_vidc:   high: 00000001: ....e: Opening video instance: 0000000000000000, 0
[   99.840199] msm_vidc:   high: 00000001: ....e: Closed video instance: 0000000000000000
[   99.848220] CAM_ERR: CAM-CPAS: cam_cpas_subdev_ioctl: 749 Invalid command -2140645888 for CPAS!
[   99.857282] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-isp
[   99.865951] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[   99.874246] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[   99.882543] CAM_ERR: CAM-ACTUATOR: cam_actuator_subdev_ioctl: 68 Invalid ioctl cmd: 2154321408
[   99.891438] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[   99.900219] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[   99.908902] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[   99.917677] CAM_ERR: CAM-FLASH: cam_flash_subdev_ioctl: 309 Invalid ioctl cmd type
[   99.925545] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-ope
[   99.934277] CAM_INFO: CAM-SMMU: cam_smmu_need_force_alloc_cached: 383 force_cache_allocs=0
[   99.943001] CAM_WARN: CAM-CRM: cam_req_mgr_close: 195 release invoked associated userspace process has died, open_cnt: 1
[   99.953972] CAM_WARN: CAM-CPAS: __cam_cpas_subdev_close: 706 device already closed, open_cnt: 0
Setting pipeline to PAUSED ...
error: XDG_RUNTIME_DIR not set in the environment.
Caught SIGSEGV
exec gdb failed: No such file or directory
Spinning.  Please run 'gdb gst-launch-1.0 2527' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
For reference please find attached boot log.
boot log.txt (114.7 KB)
@keven.wu-Q Could you assist me with this problem?
—>Please execute export XDG_RUNTIME_DIR=/run/user/root to set the environment
Hi @keven.wu-Q
I apply export XDG_RUNTIME_DIR=/run/user/root but still got below error.
(gst-plugin-scanner:2615): GLib-GObject-CRITICAL **: 08:03:42.132: g_param_spec_internal: assertion '!(flags & G_PARAM_STATIC_NAME) || is_canonical (name)' failed
[  216.510446] msm_vidc:   high: 00000001: ....d: Opening video instance: 0000000000000000, 1
[  216.521677] msm_vidc:   high: 00000001: ....d: Closed video instance: 0000000000000000
[  216.529771] msm_vidc:   high: 00000001: ....e: Opening video instance: 0000000000000000, 0
[  216.540577] msm_vidc:   high: 00000001: ....e: Closed video instance: 0000000000000000
[  216.548602] CAM_ERR: CAM-CPAS: cam_cpas_subdev_ioctl: 749 Invalid command -2140645888 for CPAS!
[  216.557742] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-isp
[  216.566442] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[  216.574876] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[  216.583268] CAM_ERR: CAM-ACTUATOR: cam_actuator_subdev_ioctl: 68 Invalid ioctl cmd: 2154321408
[  216.592387] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[  216.601267] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[  216.610153] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[  216.619078] CAM_ERR: CAM-FLASH: cam_flash_subdev_ioctl: 309 Invalid ioctl cmd type
[  216.627092] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-ope
[  216.635997] CAM_INFO: CAM-SMMU: cam_smmu_need_force_alloc_cached: 383 force_cache_allocs=0
[  216.644785] CAM_WARN: CAM-CRM: cam_req_mgr_close: 195 release invoked associated userspace process has died, open_cnt: 1
[  216.655787] CAM_WARN: CAM-CPAS: __cam_cpas_subdev_close: 706 device already closed, open_cnt: 0
[  216.910682] msm_vidc:   high: 00000001: ....d: Opening video instance: 0000000000000000, 1
[  216.921222] msm_vidc:   high: 00000001: ....d: Closed video instance: 0000000000000000
[  216.929297] msm_vidc:   high: 00000001: ....e: Opening video instance: 0000000000000000, 0
[  216.939017] msm_vidc:   high: 00000001: ....e: Closed video instance: 0000000000000000
[  216.947116] CAM_ERR: CAM-CPAS: cam_cpas_subdev_ioctl: 749 Invalid command -2140645888 for CPAS!
[  216.956405] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-isp
[  216.965204] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[  216.973694] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[  216.982087] CAM_ERR: CAM-ACTUATOR: cam_actuator_subdev_ioctl: 68 Invalid ioctl cmd: 2154321408
[  216.991144] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[  216.999923] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[  217.008783] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[  217.017595] CAM_ERR: CAM-FLASH: cam_flash_subdev_ioctl: 309 Invalid ioctl cmd type
[  217.025591] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-ope
[  217.034348] CAM_INFO: CAM-SMMU: cam_smmu_need_force_alloc_cached: 383 force_cache_allocs=0
[  217.043155] CAM_WARN: CAM-CRM: cam_req_mgr_close: 195 release invoked associated userspace process has died, open_cnt: 1
[  217.054183] CAM_WARN: CAM-CPAS: __cam_cpas_subdev_close: 706 device already closed, open_cnt: 0
GBM_INFO::msmgbm_mapper(160)::gbm mapper instantiated
gbm_create_device(225): Info: backend name is: msm_drm
gbm_create_device(225): Info: b[  217.192803] CAM_INFO: ackend name is: [  217.30msm_drm
[  217.491878] CAM_WARN: CAM-CPAS: __cam_cpas_subdev_close: 706 device already closed, open_cnt: 0
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Error getting capabilities for device '/dev/video0': It isn't a v4l2 driver. Check if it is a v4l1 driver.
Additional debug info:
../gst-plugins-good-1.16.3/sys/v4l2/v4l2_calls.c(91): gst_v4l2_get_capabilities (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: Inappropriate ioctl for device
Setting pipeline to NULL ...
Freeing pipeline ...
GBM_INFO::~msmgbm_mapper(167)::gbm mapper de-instantiated
gst-launch-1.0: /local/mnt/workspace/lnxbuild/project/trees_in_use/free_tree_dir/checkout/build-qti-distro-fullstack-noselinux-debug/tmp-glibc/work/qrbx210_rbx-oe-linux/adreno/1.0-r0/.
Aborted (core dumped)
I also probed the CAM_I2C_SDA and CAM_I2C_SCL but saw no activity on those pins.
---->Please use the following command:
gst-launch-1.0 -e qtiqmmfsrc camera=0 name=qmmf ! video/x- raw,format=NV12,width=640,height=480,framerate=30/1 ! waylandsink x=40 y=400 width=640 height=480 async=true sync=false
The v4l2 interface in your command should not be implemented, so you cannot use this command
Hi Keven,
We tried the command you suggested but still getting the following error:
root@qrbx210-rbx:~# export XDG_RUNTIME_DIR=/run/user/root
root@qrbx210-rbx:~# gst-launch-1.0 -e qtiqmmfsrc camera=0 name=qmmf ! video/x- raw,format=NV12,width=640,height=480,framerate=30/1 ! waylandsink x=40 y=400 width=640 height=480 async=true sync=false
(gst-plugin-scanner:2519): GLib-GObject-CRITICAL **: 08:01:26.063: g_param_spec_internal: assertion ‘!(flags & G_PARAM_STATIC_NAME) || is_canonical (name)’ failed
[ 71.112733] msm_vidc: high: 00000001: …d: Opening video instance: 0000000000000000, 1
[ 71.129730] subsys-pil-tz 5ab0000.qcom,venus: venus: loading from 0x0000000051400000 to 0x0000000051900000
[ 71.208936] subsys-pil-tz 5ab0000.qcom,venus: venus: Brought out of reset
[ 71.215841] subsys-pil-tz: subsys_powerup(): pil_boot is successful from venus and waiting for error ready
[ 71.262931] msm_vidc: high: 00000001: …d: Closed video instance: 0000000000000000
[ 71.271036] msm_vidc: high: 00000001: …e: Opening video instance: 0000000000000000, 0
[ 71.281893] msm_vidc: high: 00000001: …e: Closed video instance: 0000000000000000
[ 71.289986] CAM_ERR: CAM-CPAS: cam_cpas_subdev_ioctl: 749 Invalid command -2140645888 for CPAS!
[ 71.299232] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-isp
[ 71.308152] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[ 71.316750] CAM_ERR: CAM-CSIPHY: cam_csiphy_subdev_ioctl: 134 Wrong ioctl : -2140645888
[ 71.325230] CAM_ERR: CAM-ACTUATOR: cam_actuator_subdev_ioctl: 68 Invalid ioctl cmd: 2154321408
[ 71.334416] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[ 71.343318] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[ 71.352456] CAM_ERR: CAM-SENSOR: cam_sensor_subdev_ioctl: 101 Invalid ioctl cmd: -2140645888
[ 71.361367] CAM_ERR: CAM-FLASH: cam_flash_subdev_ioctl: 309 Invalid ioctl cmd type
[ 71.369562] CAM_ERR: CAM-CORE: cam_subdev_ioctl: 78 Invalid command -2140645888 for cam-ope
[ 71.378409] CAM_INFO: CAM-SMMU: cam_smmu_need_force_alloc_cached: 383 force_cache_allocs=0
[ 71.387235] CAM_WARN: CAM-CRM: cam_req_mgr_close: 195 release invoked associated userspace process has died, open_cnt: 1
[ 71.398244] CAM_WARN: CAM-CPAS: __cam_cpas_subdev_close: 706 device already closed, open_cnt: 0
WARNING: erroneous pipeline: could not parse caps “video/x- raw,format=NV12,width=640,height=480,framerate=30/1”
Just to give you better idea, We have flashed ‘qti-robotics-med-image’ image from ‘qcm2290_linux_r60_r004-SC206E_rl’ SDK as mentioned in the guide ‘Quectel_SC206E_Series_Linux_Compiling&Burning_Guide_V1.2’.
Also as mentioned in the “Quectel_SC206E_Series_Linux_Camera_Driver_Development_Guide_V1.1.pdf”, we are not seeing any camera probe success message or not even getting any I2C activity on the CAM_I2C lines.
[ 13.481824] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 753 Probe success,slot:1,sl
ave_addr:0x20,sensor_id:0x3109
So is there any modification required in Linux Build configuration or need to send additional command to probe the camera driver?
—> No, this command can be used normally. Please try the following command again:
/ # export XDG_RUNTIME_DIR=/run/user/root
/ # gst-launch-1.0 -e qtiqmmfsrc camera=0 name=qmmf ! video/x-raw,format=NV12,width=640,height=480,framerate=30/1 ! waylandsink x=0 y=0 width=640 height=480
Hi @keven.wu-Q
Thanks for your quick response.
$ export XDG_RUNTIME_DIR=/run/user/root
$ gst-launch-1.0 -e qtiqmmfsrc camera=0 name=qmmf ! video/x-raw,format=NV12,width=640,height=480,framerate=30/1 ! waylandsink x=0 y=0 width=640 height=480
Above command is working for me.
