I use ppp connection. I have set APN by AT+CGDCONT command. Now I want use APN with user, password and authentication method. What AT command provide it? AT+CGCONT only have APN parameter.
Thank you.
Thank you.
You could try the AT command
AT+QICSGP
I have already tried this command:
AT+QICSGP=1,1,“internet”,“”,“”,0
then I activated context by using:
AT+QIACT=1
Unfortunately ATD*99# returns ERROR
+CME ERROR: Operation not allowed
The way you tried ppp is wrong.
Please try the Linux PPP script.
#!/bin/sh
#quectel-pppd devname apn user password
echo "quectel-pppd options in effect:"
QL_DEVNAME=/dev/ttyUSB3
QL_APN=3gnet
QL_USER=user
QL_PASSWORD=passwd
QL_PDP=1
QL_IP=IP #IP, IPV4, IPV6, IPV4V6
if [ $# -ge 1 ]; then
QL_DEVNAME=$1
echo "devname $QL_DEVNAME # (from command line)"
else
echo "devname $QL_DEVNAME # (default)"
fi
if [ $# -ge 2 ]; then
QL_APN=$2
echo "apn $QL_APN # (from command line)"
else
echo "apn $QL_APN # (default)"
fi
if [ $# -ge 3 ]; then
QL_USER=$3
echo "user $QL_USER # (from command line)"
else
echo "user $QL_USER # (default)"
fi
if [ $# -ge 4 ]; then
QL_PASSWORD=$4
echo "password $QL_PASSWORD # (from command line)"
else
echo "password $QL_PASSWORD # (default)"
fi
CONNECT="'chat -s -v ABORT BUSY ABORT \"NO CARRIER\" ABORT \"NO DIALTONE\" ABORT ERROR ABORT \"NO ANSWER\" TIMEOUT 30 \
\"\" AT OK ATE0 OK ATI\;+CSUB\;+CSQ\;+CPIN?\;+COPS?\;+CGREG?\;\&D2 \
OK AT+CGDCONT=$QL_PDP,\\\"$QL_IP\\\",\\\"$QL_APN\\\",,0,0 OK ATD*99***$QL_PDP# CONNECT'"
OPTIONS="noauth debug defaultroute noipdefault novj novjccomp noccp ipcp-accept-local ipcp-accept-remote ipcp-max-configure 30 local lock modem dump nodetach nocrtscts usepeerdns"
if [ "$QL_IP" == "IPV6" ]; then
OPTIONS="$OPTIONS noip +ipv6"
fi
if [ "$QL_IP" == "IPV4V6" ]; then
OPTIONS="$OPTIONS +ipv6"
fi
pppd $QL_DEVNAME 115200 user "$QL_USER" password "$QL_PASSWORD" \
connect "'$CONNECT'" \
disconnect 'chat -s -v ABORT ERROR ABORT "NO DIALTONE" SAY "\nSending break to the modem\n" "" +++ "" +++ "" +++ SAY "\nGood bay\n"' \
$OPTIONS &
Modem will be used in embedded system without Linux. But I can see that user and password isn’t set by AT command, instead of that it is set in PPP session, is that correct?
Please check my Linux script.
You can run it
ppp_script.sh /dev/ttyUSBx APN user passwd
The APN user passwd is set with AT command in the script.
ATD*99# will be called but you can not take it as PPP call.
