This demo video includes:
- Quick steup for Quectel EVB kit.
- Send AT command via QCOM
Thank you for this demo!
I am trying to send AT commands firstly via WiFi connection between the embedded board with a UC20 GSM module and my PC. However, I couldn’t make it work as I didn’t receive any feedback from any of the AT commands.
Then, I connected the board via a USB cable to the PC after installing QCOM. As you can see in the attached pic, the COM port is successfully opened but no output is observed.
Do you have any idea how I can solve this issue remotely, if possible, and then via a connected method?
Thank you so much for your help in advance.
