Hi team
I need some help.
I have an EC20F module, the revision is EC20CEFAGR06A04M4G.
How can I reset my module by AT command?
How can I restart my module by AT command?
Can only control the power supply.(like AT+QPOWD)
Thanks!
Hi team
I need some help.
Thanks!
Dear Genven,
Thanks for your inquiry in Quectel Forums.
If you want to reset the module with AT command, you can try to use AT+CFUN=1,1. And AT+QPOWD is just can turn off the module, if you want to restart, you still need to press PWRKEY. Thanks!
Hopefully the above information is useful to you. Thanks!
Hi Kyson
Thank you for the response. It works for me.
It is my pleasure can help you solve the issue. You can go on your test. If you need any technical support, please do not hesitate to contact Quectel. Thanks!
