brixton
October 27, 2021, 3:01pm
#1
I’m trying to use the debug port of BC95-G. In hardware design manual it says I should use UEMonitor software. However I don’t know where to find that. Does anyone know? When I look on the internet for the UEMonitor ‘user guide’, I can find this guide o nline. But that guide doesn’t tell me where I can find the UEMonitor software itself.
Many thanks,
hi,brixton:
Download UEMonitor from the link
https://quectel123-my.sharepoint.cn/:u:/g/personal/ae-fae_dom_quectel_com_cn/EeUDa37BBDxKgjvAtkcgD2MBmCDfpNi0McdvTgkxnnTZRQ?e=yWPLcC
Before capturing logs, this tool needs license authorization, and you need to provide the corresponding sequence code. I will apply for a license for you, and then this tool can be used normally
brixton
October 28, 2021, 8:38am
#3
Many thanks! And where do I get the “message definitions” file from? xml/fwpkg? " (For BC95-G)
Please provide your module firmware version
ATI //query module version
brixton
October 28, 2021, 8:48am
#5
ATI command is not recognised/not in the AT commands manual, but CGMR is so I’m using that. Hope that’s ok.
10:47:20.654 -> AT+CGMR
10:47:20.840 ->
SSB,V150R100C10B200SP1
SECURITY_A,V150R100C20B300SP7
PROTOCOL_A,V150R100C20B300SP7
APPLICATION_A,V150R100C20B300SP7
SECURITY_B,V150R100C20B300SP7
RADIO,Hi2115_RF0
ATI is displayed as the module firmware version and CGMR is displayed as the modem chip version, so ATI information is required.
brixton
October 28, 2021, 8:57am
#7
Ahh now I found the command. I thought the command was AT+ATI but it is in fact just ATI
10:56:57.265 -> ATI
10:56:57.313 ->
BC95-G
Revision:BC95GJBR01A07
You are welcome, please replay your question and grab the Log simultaneously
Fei_Xia
January 12, 2022, 8:17am
#11
Hi pan,
I use the BC95GJBR01A07.fwpkg
bug the UEMonitor log shows:
MESSAGE:Invalid Id:ffffffff PayloadBytes:0/0 Time:0:00:00:00.0000000 Seq:0
Payload:
PayloadAscii:""
Headers=Insufficient header bytes to decipher the sequenced message header
hi,Fei_Xia:
Import the .xml file in the folder,try again!
Fei_Xia
January 12, 2022, 9:05am
#13
Fei_Xia:
UEMonitor
I click “Change Message Definition For Project” and chose the messages.xml, but it also shows:
invalid index 0 at 00:00:00
Fei_Xia
January 12, 2022, 9:07am
#14
My UEMonitor version is 3.30.0.7, do you have any other version? I can try it, thank you.
I’m currently using the same version, and I suggest you uninstall and reinstall it. What problems are you having at the moment?
Fei_Xia
January 12, 2022, 10:01am
#16
I have reinstalled it but it also doesn’t work.
I can use the AT command but I can not see the message log.
Fei_Xia
January 12, 2022, 10:04am
#17
Invalid index 0 at 00:00:00
transport
Bytes=78-66-86-86-F8-66-9E-78-66-9E-66-06-78-E6-80-98-80-00-66-F8-E6-9E-60-E6-9E-1E-E6-9E-E0-9E-00-98
As string=xf???f?xf?f.x???.f???`??.???.?
Headers=Sequencing…
SequenceNumber: 2256955000 (0x86866678)
Timestamp ticks: 2023646968 (0x789E66F8)
Framing…
Core: 1 Protocol
Class: 1 Custom
Verbosity: 2 Warning
Module: 158 (0x9E)
PayloadLength Field: 59000 (0xE678)
Payload bytes present: 18 (0x12)
Payload well-formed: 0 False
Core-specific:
Please upload your screenshots, I mean, are you having trouble with the current debugging?
Fei_Xia
January 12, 2022, 11:59am
#19
I want to do some troubleshooting, so I need to see the raw data from the UE.
