Hi, I need to publish a zero length mesage but the AT+QMTPUBEX command returns ERROR if I set the payload length to zero. A zero length publish is a common way to acknowldge/remove a retained message on a topic so this is not an ucommon thing to want to do. Is there a way to do this?
Why do you need to send null messages? If the module sends null characters, the actual data is still added to the MQTT message header; I suggest that you use some kind of definite string instead of nulls
Thanks for the response. As stated, sending a zero lentgth message is the standard way of clearing a retained MQTT message as defined in the MQTT spec [MQTT-3.3.1-11]. It is not something I want to do, it is something I am required to do. I 've done this before many times with other modems and with other MQTT stacks. See the below articles on the subject of retianed messaqges and how a zero length message is used to clear them. It’s a very common pattern. https://www.hivemq.com/blog/mqtt-essentials-part-8-retained-messages/ https://iotespresso.com/aws-iot-remove-a-retained-message/
