I can not seem to get this figured out. I am using this syntax and it keeps returning an error.
AT+QCFG=“band”,0,10000000000000,00
I keep getting an error everytime I try to send this command.
Well I finally figured out how to do what I was asking about. I will post a followup with instructions if anyone else runs across this.
Dear Jker98,
Thanks for your inquiry in Quectel forum. I am glad to hear that you have figured out your issue. You can go on your test. Thanks!
For B14 I make the command:
AT+QCFG=“band”,0,2000
Ie, bit 14 is set in the LTE bandmask, and that converted from binary to hex.
Is there some other way of doing this?
Dear Snowgum,
The method you used is quite correct. Thanks!
how did you do this. i cant get it tt work.
