How to get started?
For the basic LPWA modules (BG96, etc), where does one get info on how to use the commands to properly connect to and use LTE-M communications?
The app notes are very basic and don’t explain in much detail, and then there are AT command references with tons of commands. But when/why should I use these?
Is there a tutorial somewhere on how to do this?
Hi, Sir
Do you have any available tool to execute AT command in your side? Thx for your info
Yes, I have a Nimbelink dev board with a couple BG95/BG96 modules
