What is issue in your side? Could you specify that?
Dear Quectel Support Team,
I am currently using the Quectel EC200U-CN module with the following firmware:
Current Firmware: EC200UCNAAR02A01M08
As part of our development, we require full STK (SIM Toolkit) support to interface with our custom SIM applet. However, in the current firmware, the AT+QSTK and related commands do not function as expected.
I would like to request:
- The latest firmware version for EC200U-CN with STK support enabled
- Any associated tools (e.g., QFlash) and upgrade instructions
- Confirmation of STK feature support in the provided firmware (especially
AT+QSTKcommand compatibility)
This firmware is crucial for our STK testing and integration in our production environment.
Please share the firmware and related files via direct message or to my registered email address.
Best regards,
Sabuj De
I would like to request the latest standard firmware AT command version for the EC200U module. Current Firmware Version:EC200UEUABR03A21M08_OCPU_QPY
Please provide this exact firmware**EC25ECGAR06A06M1G_01.006.01.006). I accidentally flashed my module with the firmware for the EC25‑EU modem and it stopped working. I want to restore my original firmware back. Thank you."*
support1@itelma.by
Could you please share the latest firmware?
Recently, I purchased these two modems, the Quectel EG800 and EG915, but unfortunately, they did not work as expected.
I would kindly like to request the latest firmware versions for the EG800 and EG915 modules,
AT+CVERSION
VERSION: EG915QNALCR01A05M04
Jun 21 2023 12:16:27
VERSION: EG800QEULCR01A11M04
Oct 22 2024 09:22:43
Authors: QCT
Hello Support,
I have an LC29HDA module with firmware LC29HDANR11A03S_RSA.
The module is in a corrupted state and will not enable RTCM output (it rejects $PAIR432 and $PAIR431 commands after being set to Base Mode).
Please provide the QFlash tool and the firmware file for LC29HDANR11A03S_RSA so I can re-flash it.
Thank you.
I have an SC20WSC-8GB-UNN that I need the QFIL files for.
zoejuk@gmail.com
For Android? which Android version you want?
I have sent readback tool and readback guide to you through email, please check it. After you dump, you can compare the firmware with normal firmware.
Best regards
Android 7, thank you.
OK, I will send by E-mail later, please wait.
Hello Support,
I have an EC200A-EU based LTE Router with firmware ver. EC200AEUHAR01A12M16_01.001.01.001,
It’s old version,and sometimes I met some connection problem…
(It’s seems like EC200AEUHAR01A30M16?I am not very sure)
Much appreciated.
Hello Support
I have an EC25-AF currently with firmware EC25AFAR05A04M4G
Can you send the latest firmware. Thanks
Hi Jasper sorry for the late reply, I don’t know, yes I received the earlier message with no problems .
NEED THE FIRMWARE AS WELL AS SOFTWARE TO FLASH THE QUECTEL RG500L-AR.
it is currently supporting only one telecom operator please help me.
PLEASE GUIDE ME ANYONE
my mail is royasmit345@gmail.com
Hello, I need firmware for BG95-M3 LPWA module. I want to use QuecLocator feature but I my current firmware does not support it. Please share the firmware which supports QuecLocator or guide me where to get it.. Thanks in advance.
Could you please share the latest firmware and QFlash tool for the BC66NB-04-STD module?
Unfortunately, the AT command firmware doesn’t exist on my module anymore (no “RDY” after bootup)
Kind regards,
Ameer
For QFLASH, you may download from official webpage.
