Hello everyone,
I am developing a multi-BTS parameter extraction tool for 2G/3G/4G (GSM / UMTS / LTE). My approach is:
- Collect all passive/broadcast parameters from neighboring cells (BCCH / SIB / PHY measurements) using inexpensive consumer modules (Quectel EC25 and similar).
- Only when necessary, perform a controlled active handshake/attach to obtain parameters that truly require it.
I already know which parameters are passive vs active (I listed them in my table), and I can read AT commands such as AT+QENG="servingcell" and AT+QENG="neighbourcell". The problem I face is: standard AT commands on EC25 do not expose the RACH (PRACH) configuration and many offset/reselection fields, and I do not have QXDM. I want a reliable method to extract the remaining “hard” parameters (mainly PRACH/RACH-related and offset fields) using EC25-like modules and/or by parsing the Qualcomm DIAG port (using open tools like QCSuper / scat or a custom DIAG parser).
Concretely I need practical, low-level answers to the following:
Raw SIB/BCCH access
- Can EC25 (or similar modules) be commanded (via AT, hidden AT, QMI or a debug UART) to return raw SIB/BCCH payloads (ASN.1 / hex RRC OTA blobs)? If yes, which commands / QMI calls / serial endpoints should I try for EC25 (firmware-specific hints welcome)?
- If EC25 cannot, is the DIAG interface on Qualcomm devices the only realistic path to obtain raw RRC/SIB payloads without SDRs?
DIAG specifics
- Which DIAG packet types / subsystem IDs on Qualcomm typically carry raw RRC/SIB/BCCH payloads (or LTE-RRC PDUs)? Are there known stable IDs/fields to filter for (so I can implement a parser)?
- What does the DIAG/QCDM framing look like (header fields, msg id, subsystem id, length, payload offset)? Any short examples or annotated DIAG hex dumps would speed up development.
PRACH / RACH / offsets
- Which PRACH/RACH fields are reliably present in broadcast SIBs (and which are often omitted or vendor-specific)? In particular I need to extract:
prach-ConfigIndexprach-FreqOffsetrootSequenceIndexpreambleTransMax(PreambleTransMax)powerRampingSteppreambleInitialReceivedTargetPowerzeroCorrelationZoneConfig/ ZCZ configuration- PRACH resource lists / time-frequency resource mapping
- Which reselection/offset fields are worth collecting passively (and what are their ASN.1 names I should look for)? Examples:
cellReselectionPriority,cellReselectionOffset,qRxLevMinOffset,temporaryOffset,Qoffset.
Practical parsing / decoding
- If I obtain DIAG hex blobs containing RRC OTA payloads, is it reliable to feed them to Wireshark’s LTE-RRC dissector? If not, what ASN.1 toolchain do you recommend (asn1c / asn1tools / pycrate) and any ready schemas or parsing snippets you can share to decode SIB2→PRACH fields?
- If DIAG captures are vendor-stripped or contain only parsed fields, what are the realistic fallbacks? (e.g., controlled attach + parse RRC messages produced during attach, or using engineering logs that report PRACH indices).
Module suggestions
- If EC25 proves limited, which consumer modules or modems (firmware versions) do you recommend that (a) expose DIAG/engineering ports easily, and/or (b) provide richer debug/AT/QMI access to raw SIBs without resorting to SDR? Practical module suggestions (Sierra, Quectel variants, Qualcomm reference modules) are welcome.
Most challenging parameters I care about (please reference these names in your reply):
LTE (challenging / scientific names)
prach-ConfigIndexprach-FreqOffsetrootSequenceIndexpreambleTransMax(PreambleTransMax)powerRampingSteppreambleInitialReceivedTargetPowerzeroCorrelationZoneConfig(ZCZ configuration)cellReselectionOffset,qRxLevMinOffset,cellReselectionPriority,trackingAreaCode(TAC),timingAdvance(TA)
UMTS (challenging / scientific names)
RACH parametersin SIBs: preamble offset, maximum transmissions, max power,accessBurstsettingsUARFCN,psc,RSCP,EcNo,timingAdvance,cellReselectionOffsets/Qoffset
GSM (challenging / scientific names)
BCCH-derived fields:ARFCN,BSIC,RxLev/RxQual,Timing Advance,cell reselection offsets (Temporary Offset / Qoffset)GSM RACH related CCCH/PCCCH fields(access parameters / maximum transmit power / access class controls)
What I tried (short):
- I can already parse
AT+QENG="servingcell"andAT+QENG="neighbourcell"from EC25 and I know which fields are passive vs active in my table. Those AT outputs do not include PRACH/offsets I need. - I can open a DIAG port on rooted Qualcomm phones and can capture using QCSuper / scat, but I don’t have QXDM and want to automate DIAG→RRC parsing (open-source tools only).
- I prefer not to use SDR/USRP in this project — the goal is an EC25/DIAG-based solution, if possible.
What I can attach / share on request:
- Raw
AT+QENGoutputs from EC25 (servingcell + neighbourcell). - Sample DIAG hex/text dumps from a Qualcomm device (I can paste one or two small captures).
- EC25 firmware/modem model strings (firmware version, PID/VID) on request.
Concrete asks (please answer any you can):
- Which exact DIAG subsystem IDs / message types should I capture and parse to find raw RRC/SIB payloads (or LTE-RRC PDUs)? Any annotated DIAG dump would be ideal.
- If EC25 supports raw SIB extraction, which AT/QMI or debug endpoints should I call (firmware-specific examples appreciated)?
- If you have code snippets or tools (Python/C) that parse DIAG→RRC OTA blobs or that decode SIB2→PRACH fields, please share or point me to repos/docs.
Thank you — very concrete, low-level replies (DIAG byte layout, sample hex blob + annotation, short parser snippets) are most helpful.
