Hi! We’re working on an Arduino library for LG580P, which supports a second antenna. We are particularly interested in supporting new messages that involve the second antenna: PQTMTAR, PQTMRMC, PQTMGSV.
To enable PQTMTAR and PQTMGSV, we discovered that we can use PQTMCFGMSGRATE. (Note that this is not documented for PQTMGSV but it works.)
However PQTMCFGMSGRATE does not seem to work with PQTMRMC. How does one enable the PQTMRMC message?
Try 2 as mess.version
2.3.57.
How did U do for PQTMGSV ?
PQTMRMC arent in fw commands…
only
PQTMGSV & PQTMGSA
Please
ask for a newer fw!
Thanks @bamarcant. Summary of my findings:
PQTMCFGMSGRATE with PQTMGSV and MsgVer=2 worked
PQTMCFGMSGRATE with PQTMRMC and MsgVer=(0..9) doesn’t work.
I’m very interested in your second post. It seems you are showing a dump of the BETA1017 binary and this shows that the string PQTMRMC is no found anywhere? And this suggests that maybe this message is not yet supported, at least in this version? Very good analysis! Thanks!
Quectel, how can one get a firmware newer than 04:
$PQTMVERNO,LG580P03AANR01A04S_SH,2025/06/06,10:08:42*54
M
Hi Mikalhart, Bamarcant,
RMC and GSV are standard NMEA protocol. Thus there is no PQTMRMC or PQTMGSV defined. For standard NMEA protocol, the talker ID is always composed of 2 letters.
GGA, GSA, VTG, GLL, ZDA … etc are also follow the rules above. It isn’t related to any firmware.
PQTM is proprietary protocol that only supported by Quectel GNSS modules.
BR,
Hello @Raphael-Q, we are talking about
PQTMGSV & PQTMGSA, defined into fw…and also in gnss_manual at 2.3.57
Please, Wu Hanxiang, can ve have latest firmware (also beta) that support this feature?
Thank for Your reply.
Regards
Marco
Hi @mikalhart
The current firmware LG580P03AANR01A04S_SH is the latest version for LG580P, i will send you the latest version once available.
For the RMC after giving command $PQTMCFGMSGRATE,W,RMC ,1 * 37, try $PQTMSAVEPAR *5A and reboot module.
Best regards
Hello @YongHuang, did you read capter 2.3.57 of quectel_lg290p03lgx80p03_gnss_protocol_specification_v1-1
available in https://www.quectel.com/content/uploads/2024/09/Quectel_LG290P03LGx80P03_GNSS_Protocol_Specification_V1.1.pdf
regarding “Antenna 2 Proprietary Message”.
Please need info for PQTMGSV & PQTMGSA and why is not supported PQTMRMC still mentioned into examples…
Hi @mikalhart , @bamarcant ,
Sorry I didn’t have a LG580P03 before. Now I have it.
Yes. LG580P supports PQTMGSV and PQTMGSA on LG580P03AANR01A04S_SH. While PQTMRMC or PQTMGGA are not supported. LG580P gives the PVT (position, velocity, time) basing on master antenna (ANT 1). If you connect only salve antenna (ANT 2), it can not get basic position fixed.
Enable them by $PQTMCFGMSGRATE,W,PQTMGSV,1,2*0F
$PQTMCFGMSGRATE,W,PQTMGSA,1,2*18
BR,
Tanks for the confirmation.
Buone feste a tutti
@Raphael-Q
“PQTMRMC is not supported”
Please clarify, because the Protocol Specification shows it in the example on p 102 (Section 2.3.57). Is the document in error? Or is this planned for the future?
Thanks!
Just checking in the new year… @Raphael-Q is it planned to support $PQTMRMC in a future firmware release?
Hi Mikalhart,
We expect to have PQTMRMC supported by the end of 2026 Q1.
BR,
Hello! I’ve been absent awhile and just wanted to check whether a new firmware implementing PQTMRMC on the LG580P has been released.
Cheers,
Mikal Hart
Hi @mikalhart after further check with our internal team, the LG580P does not support independent positioning with a secondary antenna.
If this functionality is essential for your application, I recommend contacting our product or sales team directly for further assistance: Kunal Ravindra Rege: kunal.rege@quectel.com
Best regards,
