Which AT commands for enabling 5G network and GNSS service in RM520N-GL module?
Default RM520N-GL module is 4G enabled?
Pls support me regarding
Dear @iotmani
The 5G network is enabled by default. Could you help to confirm if there have 5G network or not?
For GNSS, I have sent the documemt to you via Message, please check.
Thanks for response
i am facing two issues
- my module and sim supports 5G and 5G network is available in my location, but in my mobile network settings showing 4G only.
- I tried to run GNSS using AT commands (document u shared) but i am getting these error
AT+QGPS=1
AT+QGPSLOC=0
- CME Error : 516
Please help me out solve this error for getting GPS information?
my module details RM520N-GL
firmware version: RM520NGLAAR01A06M4G
Hi @silvia
Same problem here.
Enabled the GPS via AT+QGPS=1
Checked the #W_DISABLE2 pin → not connected / pulled up internally
Getting NMEA messages but not a fix.
Config:
AT+QGPS?
+QGPS: 1
AT+QGPSEND
AT+QGPSXTRA=1
AT+QGPSXTRADATA?
+QGPSXTRADATA: 0,“1980/01/06,00:00:00”
AT+QGPSXTRATIME=“2023/10/30,22:05:55”,0
AT+QGPS=1,240,1
Decoded NMEA-Messages (Latitude, Longitude, Time):
0.0
0.0
22:05:56.450000+00:00
0.0
0.0
22:05:57.450000+00:00
0.0
0.0
22:05:58.450000+00:00
0.0
0.0
22:05:59.450000+00:00
0.0
0.0
22:06:00.450000+00:00
0.0
0.0
22:06:01.450000+00:00
Best regards
Ronny
Could you get any help !?
I’m facing same error.
Facing same issue in rockchip rk3588 based board.
