Hello
I’m hoping someone can point me towards the right direction.
I’m trying to use an i2c ILI2130 touch panel with the SC668S-EM (on SMART EVB G5).
This is what I’ve done so far:
Ensure that hardware connections are there (reused the same touch panel connector) to use the same interrrupt and reset GPIO.
Modify trinket-idp.dtsi file to include the ilitek touch panel used and added the following below:
ilitek_ts@41 {
compatible = “ilitek,ili2130”;
reg = <0x41>;
interrupt-parent = <&tlmm>;
interrupts = <88 0x2008>;
ilitek_ts,reset-gpio = <&tlmm 87 0x0>;
ilitek_ts,irq-gpio = <&tlmm 88 0x2008>;
//goodix,power-gpio = <&pm660l_gpios 3 0>;
vdd_ana-supply = <&eldo1>;
vcc_i2c-supply = <&L12A>;
pinctrl-names = “pmx_ts_active”,“pmx_ts_suspend”;
pinctrl-0 = <&ts_int_active &ts_reset_active>;
pinctrl-1 = <&ts_int_suspend &ts_reset_suspend>;
Modify the touch drivers makefile to include the ilitek touch panel used:
obj-$(CONFIG_TOUCHSCREEN_ILITEK_TS) += ilitek_ts_i2c.o
- Copied ilitek_ts_i2c.c to the touch drivers folder (kernel/msm-4.14/drivers/input/touchscreen/) source link below:
ilitek_ts_i2c.c - drivers/input/touchscreen/ilitek_ts_i2c.c - Linux source code (v6.5) - Bootlin
After I compile and build, the touch panel still does not work, any ideas? Perhaps I’ve missed out some steps?
Thanks a lot
