How to change the version of MQTT protocol on M66
hai,
An error is occurring when I change the version of the MQTT protocol to 3. the command I used is
.on documents they given that .each time I tried this command occurring an error. I am getting an “ok” response when I try this command AT+QMTCFG=“version”,0,0.
hello I hope that help… I don’t know which is your TCPConnectID have you try
//AT+QMTCFG="version",<TCPConnectID>,<mqtt_proto_ver>\r
AT+QMTCFG="version",0,3\r
I tried this command which is shown on the 1st picture with CME ERROR 3765 (invalid input value) :frowning_face:
I am sorry for insisting but
into the first picture the second param is 1 like this, the change is surrounded by triple *
AT+QMTCFG="version",***1***,3
I said you can try
AT+QMTCFG="version",***0***,3
this is because at previous command
//AT+QMTCFG="ssl",<tcpConnectID>,1,<ctx_index>
AT+QMTCFG="ssl",0,1,2
@stbnrivas thanks for the reply. I tried that too
issue solved.i have used wrong data sheet. command is AT+QMTCFG=“VERSION”,0,1
