Sorry for the FAQ, I need to run 4G LTE for IoT data communication in Linux and oFono platform 24 / 7 environment, has anyone tested EC-200U in Linux platform and oFono QMI prototol?
In 24 / 7 operations, it is no doubts that the LTE registration can be disconnected, how stable that oFono can manage EC-200U to be reconnected?
Last, has anyone test SSH tunneling to remotely log in to the device via 4G LTE network interface, how stable it is to run commands in Linux SSH console?
sorry,i didn’t quit understand what you means.
1- For QMI, it is only applicable to Qualcomm platform, EC200U is RDA platform.
2- For oFono,EC200U don’t support such function and we haven’t debugged it.
3- EC200U is an RTOS system, it does not have a background login management system, like adb, so SSH cannot log in to EC200U
Thanks for your response, please see my inline comments.
As I mentioned I was talking about supporting quectel 4G LTE device in oFono using QMI protocol.
No really, QMI protocol is used in oFono, there are many 4G LTE chips are supported QMI in oFono, please check oFono plugin, you will see details.
There are quectel and quectelqmi setup in oFono, if it is not for EC200U, which quectel 4G LTE chips are supported in oFono under the quectel and quectelqmi setup?
If Quectel only supports EC200U for RTOS, then it is a wrong chip, we cannot use it. Thank you for your advice.
To be honest, we are really unfamiliar with oFono. Unless there are customers who have used it, we may learn some information during the support process, because you also mentioned the use requirements of QMI. Although QMI is cross-platform, but it is In terms of underlying development, if you want to use QMI, it must be based on Qualcomm platform products.
I think the 4G products base the Qualcomm platform should be able to meet your requirements, such as EC21, EC25, etc.
Thanks for your advice, is it correct that EC21 is for 4G LTE CAT 1, right? Looked at it, theLTE bandwidth is 10Mbps and uplink rates of 5Mbps is the maximum, what is the normal consistent bandwidth? I need to run SSH tunneling on CAT 1, if the bandwidth is too low or varied too much that won’t work, that is why I switched from Cat M1 to Cat 1. Has anyone used SSH tunneling on CAT 1?
As we all know, this is a theoretical value. There are many factors that affect the real network , so we can’t guarantee it. Normally, FDD 6~7Mbps(DL) and 2~3Mbps(UL).
