Hi
I use EPAT for capture BC660K-GL module’s log.
But a lots of logs are undecoded because of Version difference
PC ver. 0x65084851 and UE ver. 0x1378732c
I don’t have any text file for update.
How can I get ‘update text file’?
Thanks.
Hi
Thanks.
hi,jkpark:
Please check the version of your modem through the following AT Command, and then I will send you the corresponding parse file.
ATI
I have uploaded the version: BC660KGLAAR01A03_01.002.01.002. If yours is the same as this version, please click the link to download it directly.
https://quectel123-my.sharepoint.cn/:u:/g/personal/ae-fae_dom_quectel_com_cn/ETzDNwCRSUlOq6SNfqbmTKAB2TT32EPuIVy_L1W6qsnqqg?e=zTU5X9
Hi herbert.pan
I try ATI on my BC660K-GL module
ATI
Quectel_Ltd
Quectel_BC660K-GL
revision: BC660KGLAAR01A03
I can’t see version info after ‘_’.
In EPAT sigLogger
–Compiled: Jan 23 2021 16:48:47
I think I need to update FW in BC660K-GL, How can I update it?
I am having the same problem, I am using EPAT to capture BC660K-GL module’s log, but all of the logs are encoded.
UE ver. 0x00000000
PC ver. 0x65084851
pls run the AT command
AT+QGMR
pls run the at command
AT+QGMR
