How do I set up a WiFi APN with EC-200U-EU?
According to the documentation, it’s possible to configure a WiFi access point using the EU-200C module QuecDevZone. I’m encountering an issue when importing the module related to the ‘SLIP’ on (Serial Line Internet Protocol) package related to “usr.WLAN import ESP8266”. It seems that this package is not available in my firmware. Can you help me find a solution? QuecDevZone
hi,
Yes, the EC200U supports ESP8266.However, custom firmware is required.Can you tell me the email address? I’ll email it to you
Please send it to me. This is my email pp.napapol@gmail.comp
hi, Napapol
The following link is the firmware of EC200U and ESP8266, please try it, thank you
Firmware version: ESP8266_SLIP_X26M_BETA20240301
F
Firmware version: EC200UEUAAR03A01M08_BTLVGL_OCPU_QPY_BETA0429B
I have an issue when installing firmware version: EC200UEUAAR03A01M08_BTLVGL_OCPU_QPY_BETA0429B found no USB NMEA port.
hi,Napapol
please select REPL Port to debug
I see, I have tried following the steps in this example AP Mode but my phone warns me that there is no internet.
hi,
Do you mean the phone can’t search for wifi?
Can you share the script and method of the test with me? Let me have a try
Hi, Felix.feng-Q
I’ve checked this firmware version “EC200UEUAAR03A01M08_BTLVGL_OCPU_QPY_BETA0429B” and it seems that the firmware includes the LVGL support which is very nice.
But I noticed that the Quecpython VoiceCall module isn’t embedded in the firmware although its AT-commands is embedded in the firmware and works fine.
Can you check if there is such a firmware that supports both in QuecPython?
Also is there anywhere we can enroll to receive these Beta firmwares and provide feedbacks?
Thank you
hi,
yes,You are right. EC200UEUAAR03A01M08_BTLVGL_OCPU_QPY_BETA0429B not suport voiceCall.
May I ask, do you need LVGL, BT and voiceCall?
I’ve sent you a message
Thank you for the quick response
May I ask how you sent the message to me? By mail?
I just clicked on your profile name and used chat
which way you prefer? by email?
hi
I’ve read your message.
Could you provide your email address? Let’s communicate by email.
Because your requirements are complex, we may need to evaluate them through an internal team
Hi
I just sent you my email through DM
Please check chat
Thank you
ok I already sent you an email
Would it be possible to share a version that supports wifi with esp8266 again? Above links appear inaccessible
hi, pat
please give me your email address. i provide it to you through email.
Hi Felix, I have sent you a DM a couple of days ago. Could you check the receival and send me the firmware? Thank you.
hi,pat
Sorry for late reply. I have already provided it to you via email.
