Thanks. There appears to be an error in the documentation for AT+QENG . According to page 104, the response for AT+QENG=“servingcell” in EN-DC mode should be of the form:
+QENG: "servingcell",<state>
+QENG: "LTE",<is_tdd>,<MCC>,<MNC>,<cellID>,<PCID>,<earfcn>,<freq_band_ind>,<UL_bandwidth>,<DL_bandwidth>,<TAC>,<RSRP>,<RSRQ>,<RSSI>,<SINR>,<CQI>,<tx_power>,<srxlev>
+QENG: "NR5G-NSA",<MCC>,<MNC>,<PCID>,<RSRP>,<SINR>,<RSRQ>,<ARFCN>,<band>,<NR_DL_bandwidth>,<scs>
That is, three lines starting with +QENG.
The first two lines conform to the description, however, the third line (starting with +QENG: “NR5G-NSA”) should be followed by 10, comma separated values. I only get 6, example output:
+QENG: "NR5G-NSA",240,02,65535,-32768,-32768,-32768
Do you know why I am seeing this discrepancy and what the values returned correspond to?
