How can i update my BG77 Firmware?
Hello Everyone,
I have BG77 Module witch has following firmware version,
BG77LAR02A04
i want to upgrade it, How to update and Where can i download it?
@herbert.pan-Q
Hi @Akshit279
Which target version do you need?
Hi @Linkin-Q
I need latest version for BG77 module.
at this time i have BG77LAR02A04_01.003.01.003 this version.
Hi @Linkin-Q
Can you please provide steps to update new firmware on my bg77
Hi @Linkin-Q
I receive this error msg when upload FW files in QFLASH tool
remove the space in the tool path or fw path.
Hi @Linkin-Q
Yes this Space related problem was solved,
now another issue is started
when i select port and baud rate(In my case it is port 6 and baud i selected is 3000000)
I received this type of msg my port was not detected , I already install driver as mention in document
@Akshit279
Please do not change firmware floder name.
Hi, @Linkin-Q
Okay so i done unzip files again in D partition only,
it’s fine with it that files in D drive or it should be in c drive only?
This is not required for saving partition D or C.
Now this msg is appear,
the correct folder should be like this:
E:\xxxxxx\BG77LAR02A04_01.003.01.003 in this folder are update files
