How can I obtain test authentication parameters for the AG591ECN on-chip eSIM profile?
I am using a Quectel AG591ECN 5G module with the following firmware:
AG591ECNEAR01A04M8G_OCPU_CYF_F01
The module is installed in a T-Box and is connected to a private 5G SA test network built with:
  • USRP B210
  • OCUDU/srsRAN-based gNB
  • Open5GS 5GC
  • NR band n78
  • PLMN 001/01
This firmware exposes the following configuration:
AT+QCFG=“sim/onchip”,1
After enabling this option, the module reports:
  • SIM status: READY
  • IMSI: 001010123456789
  • ICCID: [please fill in, or redact part of it]
The module can detect and scan my private PLMN, but it cannot complete 5G-AKA registration. Open5GS reports an
authentication MAC failure.
I understand that the K and OPc values cannot be read from the eSIM. I am not asking how to extract secrets from
the eSIM.
Could you please clarify:
  1. Is IMSI 001010123456789 a Quectel factory test eSIM profile?
  2. Is there an official test subscriber record containing the corresponding K, OPc, AMF, and authentication
    algorithm?
  3. Is Milenage or TUAK used by this profile?
  4. Is there an authorized way to obtain the matching Open5GS authentication parameters?
  5. Is this on-chip eSIM profile intended to work only with a specific test core network?
  6. Is there a newer firmware or document for using this profile with a private 5G SA network?
  7. Is the profile replaceable through eSIM/eUICC management, or is it permanently provisioned?
For reference, the module can read the IMSI and ICCID successfully, but authentication fails after the network
sends the authentication challenge. I can provide sanitized Open5GS logs and modem registration logs privately if
required.
Thank you.
Thanks for your detailed questions. Please find our replies below:
1.Is IMSI 001010123456789 a Quectel factory test eSIM profile?
Yes. It uses the 3GPP reserved test number range (MCC 001). Please note that this is an on-chip test SIM stored in the module’s NV files, not an eUICC/eSIM profile.
2.Is there an official test subscriber record containing the corresponding K, OPc, AMF, and authentication
algorithm?
The on-chip SIM is for CMW500 testing only. Quectel does not use this on-chip SIM for our internal tests; we use physical SIM cards instead. It cannot be loaded with physical SIM credentials and function like a physical SIM card, contrary to your understanding.
3.Is Milenage or TUAK used by this profile?
--Neither. The default factory image uses fixed authentication response (FIXED), without Milenage or TUAK algorithm calculation. The module only supports FIXED / XOR / MILENAGE algorithms; TUAK is not supported.
4.Is there an authorized way to obtain the matching Open5GS authentication parameters?
--Not available at present.
5.Is this on-chip eSIM profile intended to work only with a specific test core network?
Yes. The on-chip SIM only works with CMW500.
6.Is there a newer firmware or document for using this profile with a private 5G SA network?
The current on-chip SIM is only compatible with CMW500 and cannot work with self-built private 5G SA networks. We recommend you use a physical SIM card.
7.Is the profile replaceable through eSIM/eUICC management, or is it permanently provisioned?
It can be replaced and is not permanently burnt-in. It is a regular module NV file: /nv/item_files/modem/uim/mmgsdi/onchip/onchip_slot1. Full file replacement can be done via QPST/QMSL EFS Explorer or images provided by Quectel. This is unrelated to eSIM/eUICC (LPA) management.
