How can I get a new firmware for EC25EUX
I have problems sending sms messages with ec25eux current firmware is EC25EUXGAR08A13M1G. I read that the problems are solved with a newer firmware e.g. EC25EUXGAR08A17M1G. How can I get this?
I have sent the latest firmware to your email, pls check
I’ve got the email. Thank you very much for your fast help!
Sorry for hijacking this topic, but I am experiencing the same issue when trying to send SMS message.
I have the same dongle (EC25-EUX) and firmware version (EC25EUXGAR08A13M1G) as @DanielBorer.
Can you email the latest firmware version for the dongle?
Thanks!
Hi!
My requirements are a bit unusual.
I have 2 of EC25:
EC25EUXGAR08A08M1G
EC25EUXGAR08A19M1G
the newer one (v19) has a defect from my point of view - “parasitic” ~+600 ms delay in case bufferbloat in uplink occurs, which v08 does not have.
as I have read:
The new firmware version cannot be downgraded to versions released before EC25EUXGAR08A13M1G, otherwise the module will not be able to work normally.
If I cannot install v08 over v19 even if I had it, can I get v13 ?
I have sent the v14 to your email, pls check
Dear Quectel Support Team,
I am currently using a Quectel EC25-EUX LTE module integrated in a USB dongle.
The module reports the following information via the ATI command:
  • Model: EC25EUX
  • Revision: EC25EUXGAR08A07M1G
  • Current version, EC25EUXGAR08A07M1G_01.001.01.001
I would like to kindly request:
  1. The official firmware package (.pac or equivalent) for this exact revision (EC25EUXGAR08A07M1G), so that I can keep a backup of the original firmware before performing any upgrades.
  2. The latest recommended firmware for the EC25-EUX series (GAR08AxxM1G branch), including any release notes or documentation you can provide (changelog, known issues, etc.).
  3. The latest official version of your firmware upgrade tool for Windows (QFlash / Quectel Software Upgrade Tool), compatible with the EC25-EUX, along with any relevant usage guide.
The module is currently used for development, testing and evaluation purposes (non‑production).
If you require any additional information (IMEI, serial number, region, operator), I will be happy to provide it.
Best regards,
I have already shared the latest firmware and upgrade tools with you. Please check them.
I would like to request the official firmware package EC25EUXGAR08A17M1G for the EC25EUXGR-128-SGNS hardware variant.
If possible, could you also provide the latest Linux source archive for the QFirehose upgrade tool?
Thank you in advance for your assistance.
Hello Quectel Support,
I would like to request the latest stable firmware for my Quectel EC25-E module.
Module: EC25-E (SN: 869305071826088)
Current firmware:
EC25EFAR06A17M4G
AT+QGMR:
EC25EFAR06A17M4G
Country: Hungary
Could you also provide the firmware upgrade tool and upgrade guide?
Thank you.
Dear Customer,
I have sent the latest firmware of EC25-EUXGA and Qfirehose through email. Please check there.
Dear Customer,
I have sent the latest firmware through your email together with Qflash tool for upgrade. Please check there.
Title: Latest DFOTA firmware for EC25-EUX – currently on EC25EUXGAR08A19M1G_DFD_A0.300.A0.300
I am using a Quectel EC25-EUX module and would like to confirm the latest available production firmware and DFOTA upgrade path.
The module is currently running:
ATI
EC25
Revision: EC25EUXGAR08A19M1G
AT+QGMR
The module was previously running:
EC25EUXGAR08A11M1G_20.003.20.003
I successfully upgraded it to A19 using the following DFOTA package:
to
The upgrade completed successfully with:
+QIND: "FOTA","END",0
I would like to know:
1. Is EC25EUXGAR08A19M1G_DFD_A0.300.A0.300 currently the latest production firmware for EC25-EUX?
2. If a newer firmware is available, what is the latest firmware version?
3. Is there a DFOTA delta package that can upgrade directly from my current version:
to the latest version?
4. If a direct DFOTA package is not available, please advise the recommended upgrade path.
5. Please also provide the firmware release notes/change log, if available.
The module is being used in an embedded Linux data logger, so I specifically need a DFOTA-compatible production firmware rather than a development/test build.
Thank you.
Best regards,
Nithin
