Help to install modem EP06-E with Linux OpenWRT or Windows 10
Dear Support Team,
Please help us what should I do, this first I used quectel product with type :
Bus 001 Device 004: ID 2c7c:0306 Quectel Wireless Solutions Co., Ltd. EG06/EP06/EM06 LTE-A modem
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I buy from aliexpress :
https://www.aliexpress.com/item/1005001561321478.html?spm=a2g0s.9042311.0.0.8cba4c4dq41pwO
Help me please because I trying to read all from google and still not working.
Best regards
Hi Sir,
On Linux platform please follow the
https://www.quectel.com/download/quectel_wcdma-lte_linux_usb_driver_user_guide_v1-8/
and modify the Linux Kernel.
Dear Mr. Wang
Thank you very much for the information, do you have this file code or I just need to add new one?
Best regards
Quectel_LTE&5G_Linux_USB_Driver_User_Guide_V2.0.pdf (564.5 KB)
You don’t know how to modify the kernel ?
You can google with keyword qult and openwrt.
Mr. Wang, I used AT command to check my modem and get status like this. but I check the modem still can’t detect LTE Network and other Network.
Does this problem cause band or something Mr wang ?
Best regards.
Check AT+COPS?
If so, check the signal with AT+CSQ
Dear Mr. Wang
1). Log Message USB
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 5.08
S:  Manufacturer=Linux 5.8.18-libernet xhci-hcd
S:  Product=xHCI Host Controller
S:  SerialNumber=xhci-hcd.3.auto
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#=  6 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=2c7c ProdID=0306 Rev= 3.10
S:  Manufacturer=Quectel
S:  Product=EP06-E
S:  SerialNumber=0123456789ABCDEF
C:* #Ifs= 5 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=83(I) Atr=03(Int.) MxPS=  10 Ivl=32ms
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=85(I) Atr=03(Int.) MxPS=  10 Ivl=32ms
E:  Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=87(I) Atr=03(Int.) MxPS=  10 Ivl=32ms
E:  Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E:  Ad=89(I) Atr=03(Int.) MxPS=   8 Ivl=32ms
E:  Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=5000 MxCh= 0
D:  Ver= 3.00 Cls=09(hub  ) Sub=00 Prot=03 MxPS= 9 #Cfgs=  1
P:  Vendor=1d6b ProdID=0003 Rev= 5.08
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=(none)
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms```
Best regards
Dear Mr. Wang,
bellow detail AT command does it normally? how to check status band config? my place available LTE 1800 and 2100
I have the same situation and I am following the solution of the problem with interest.
Many thanks.
Massimo
