Help getting started with EC200U
I’ve gotten a Quectel EC200U and connected it to Linux using USB.
This is what I am trying to do :
  • Establish AT communication with the device and get a feel for it
  • Try to get the EC200U to provide internet through USB to linux, to make sure the SIM works
  • Try to do some basic communication, download a HTTP and HTTPS target using bare communication (AT commands, maybe)
  • Eventually redo all of this with a Cortex M0 using UART.
I’m having some trouble establishing AT communication with the module from a regular linux host. The responses from the module don’t look like what I was expecting. When I send AT, I get this response repeatedly (among other similar looking text) :
%DBG<0x88><0x17><break x 002>
~<0xba><0x13><break>
<0x05><break x 004>
<0xe0><break x 002>
<0x08><break>
<0xee><0xf8>e<0xff>h<0xfa>F<break>
EE
I believe this is the relevant output of cat /sys/kernel/debug/usb/devices:
T:  Bus=03 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 26 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=2c7c ProdID=0901 Rev= 3.18
S:  Manufacturer=Android
S:  Product=Android
C:* #Ifs= 9 Cfg#= 1 Atr=e0 MxPwr=400mA
A:  FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=06 Prot=00
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=06 Prot=00 Driver=cdc_ether
E:  Ad=81(I) Atr=03(Int.) MxPS=  16 Ivl=32ms
I:  If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=83(I) Atr=03(Int.) MxPS= 512 Ivl=4096ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 7 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=8a(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=89(I) Atr=03(Int.) MxPS= 512 Ivl=4096ms
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E:  Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
This is the relevant portion of dmesg when I connect:
 2462.697349] usb 3-2: new high-speed USB device number 26 using xhci_hcd
[ 2462.825242] usb 3-2: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 32, changing to 9
[ 2462.827192] usb 3-2: New USB device found, idVendor=2c7c, idProduct=0901, bcdDevice= 3.18
[ 2462.827196] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2462.827199] usb 3-2: Product: Android
[ 2462.827201] usb 3-2: Manufacturer: Android
[ 2462.931935] cdc_ether 3-2:1.0 usb0: register 'cdc_ether' at usb-0000:04:00.3-2, CDC Ethernet Device, 02:4b:b3:b9:eb:e5
[ 2462.933734] option 3-2:1.2: GSM modem (1-port) converter detected
[ 2462.934006] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB0
[ 2462.935101] option 3-2:1.3: GSM modem (1-port) converter detected
[ 2462.935768] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB1
[ 2462.936819] option 3-2:1.4: GSM modem (1-port) converter detected
[ 2462.937236] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB2
[ 2462.938455] option 3-2:1.5: GSM modem (1-port) converter detected
[ 2462.938916] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB3
[ 2462.939861] option 3-2:1.6: GSM modem (1-port) converter detected
[ 2462.940003] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB4
[ 2462.940618] option 3-2:1.7: GSM modem (1-port) converter detected
[ 2462.940791] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB5
[ 2462.941373] option 3-2:1.8: GSM modem (1-port) converter detected
[ 2462.941512] usb 3-2: GSM modem (1-port) converter now attached to ttyUSB6
[ 2463.552861] cdc_ether 3-2:1.0 enx024bb3b9ebe5: renamed from usb0
The operating system is Ubuntu Linux 24.04, 6.8.0-40-generic
Any help would be appreciated.
Additional information:
I am using CuteCom for communication. I’ve configured it to connect to /dev/ttyUSB2, 115200, 8N1, with CR/LF line endings.
ModemManager is presently disabled. When ModemManager is enabled, Ubuntu’s network manager briefly shows a “Connecting to Network” on the Wired Network, and then it switches to Media DIsconnected.
The problem seems to be a linux only problem. Windows serial terminals YAT and Realterm are working fine.
ModemManager has been disabled on linux, but I suspect there’s something else that needs to be done for linux to not push the module into the strange state that it does.
Looks wrong to me: the AT port for this modem is If#= 2 that is mapped to /dev/ttyUSB0 in your case.
You are correct. Apparantly it is on /dev/ttyUSB0 and it responds normally to AT commands on that interface.
Thank you !
Hello I just bought EC200U-EU Dongle to use it with Linux .
But Dongle didn’t take ttyusb ports
I try it in NDIS and ECM mode but same problem
How can solve this problem please ?
show the output of cat /sys/kernel/debug/usb/devices
Hello
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 6
B: Alloc= 0/800 us ( 0%), #Int= 1, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 4.18
S: Manufacturer=Linux 4.18.0-477.27.1.el8_8.x86_64 ehci_hcd
S: Product=EHCI Host Controller
S: SerialNumber=0000:02:04.0
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
S: Product=Android
A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=03
I:* If#= 0 Alt= 0 #EPs= 1 Cls=e0(wlcon) Sub=01 Prot=03 Driver=rndis_host
E: Ad=82(I) Atr=03(Int.) MxPS= 8 Ivl=4096ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I:* If#= 7 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 4.18
S: Manufacturer=Linux 4.18.0-477.27.1.el8_8.x86_64 uhci_hcd
S: Product=UHCI Host Controller
S: SerialNumber=0000:02:03.0
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0e0f ProdID=0003 Rev= 1.02
S: Manufacturer=VMware
S: Product=VMware Virtual USB Mouse
C:* #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
I:* If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 3 Spd=12 MxCh= 7
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0e0f ProdID=0002 Rev= 1.00
S: Manufacturer=VMware, Inc.
S: Product=VMware Virtual USB Hub
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=255ms
Make sure your Linux kernel is not outdated then run sudo modprobe option then re-read and see if there is a change with Driver=
Once AT command port is available, switch to ECM with AT+QCFG="usbnet",1
I’m very sorry. I’m a beginner. So, can you explain more ?
now I change mode to ECM by At command AT+QCFG=“usbnet”,1
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
S: Product=Android
[root@issabel ~]# ls /dev/ttyUSB*
ls: cannot access ‘/dev/ttyUSB*’: No such file or directory
my Linux version
NAME=“Rocky Linux”
VERSION=“8.8 (Green Obsidian)”
ID=“rocky”
ID_LIKE=“rhel centos fedora”
VERSION_ID=“8.8”
PLATFORM_ID=“platform:el8”
PRETTY_NAME=“Rocky Linux 8.8 (Green Obsidian)”
ANSI_COLOR=“0;32”
LOGO=“fedora-logo-icon”
CPE_NAME=“cpe:/o:rocky:rocky:8:GA”
HOME_URL=“https://rockylinux.org/
BUG_REPORT_URL=“https://bugs.rockylinux.org/
SUPPORT_END=“2029-05-31”
ROCKY_SUPPORT_PRODUCT=“Rocky-Linux-8”
ROCKY_SUPPORT_PRODUCT_VERSION=“8.8”
REDHAT_SUPPORT_PRODUCT=“Rocky Linux”
REDHAT_SUPPORT_PRODUCT_VERSION=“8.8”
thank you
According to Google, the default kernel version for Rocky Linux 8.8 is 4.18.0
That is very old version (from 2023?), so your modem (Vendor=2c7c ProdID=0901) is not yet supported there.
Thank you so much
what can i do ?
can update Linux ?
what target version i need ?
According to my notes, support for this modem was added in v5.15.90
Thank you so much my friend
Update version and it work
[root@issabel ~]# uname -r
5.15.202-1.el8.elrepo.x86_64
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB3 /dev/ttyUSB4 /dev/ttyUSB5 /dev/ttyUSB6
now I want to use modem to make calls with Asterisk and I want just 2 ttyUSB ports for (data & voice) i don’t need all this ports
and linux take ip from modem
[root@issabel ~]# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0c:29:95:a0:56 brd ff:ff:ff:ff:ff:ff
altname enp2s0
altname ens32
inet 192.168.100.128/24 brd 192.168.100.255 scope global dynamic noprefixroute eth0
valid_lft 1566sec preferred_lft 1566sec
inet6 fe80::20c:29ff:fe95:a056/64 scope link noprefixroute
3: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 02:4b:b3:b9:eb:e5 brd ff:ff:ff:ff:ff:ff
altname enp2s4u1
altname ens36u1
How can disable it ?
thank you
