From the picture, I don’t see any useful information. If the USB cannot communicate, first check whether the module is turned on. Ensure that you can connect to the PC with a USB cable after normal boot; at the same time, you can also use a bare module to perform a flying line test to find out whether the board is a problem or a module problem, and narrow the scope of the problem.
