HeliosSDK EC200UCNAA REPL not working
I followed these instructions to compile the Helios SDK for EC200UCNAA. After flashing the generated firmware the REPL port is not showing, So i tired flashing the firmware given here it worked on the NMEA port. But the NMEA port is not working with the firmware generated by me (port is opened but can’t run any python code in REPL of QPYcom). Attaching the HeliosSDK config for reference
So is there anything I need to do to run code in REPL via NMEA port ?
Please assist on this
Please use this compile command
helios make services\microPython @EC200UCN_AA EC200UCNAAR02A01M04_OCPU_QPY_BETA0822
Hi
Unfortunately this also didn’t work i am attaching the archive of compiled firmware files for reference.
EC200UCNAAR02A01M04_OCPU_QPY_BETA0822.zip (4.6 MB)
Please check those once. Also please let me know if any other details required.
Also I have another doubt, is the REPL disabled by default when compiled from HeliosSDK ?
hi,
Could you tell me the SDK version (name of SDK)? Let me have a try
I just followed the steps given in https://python.quectel.com/doc/Application_guide/en/helios-sdk/quick-start.html for EC200U-CN
And cloned https://gitee.com/quecpython/HeliosSDK.git
And didn’t choose any specific version.
May I ask why you need to use the SDK for development? Generally, Quecpython is developed using FW
I used helios make services\ microPython@EC200UCN_AA EC200UCNAAR02A01M04_OCPU_QPY_BETA0822 to compile the SDK on the website, but the compilation failed. This should be related to the older version of the SDK
Reason for using the SDK for development is i have my python module that needs to be converted as a frozen module.
But i m just compiling the cloned SDK (not including the my python module) to check if the basic compiled firmware is working or not.
I am having the same version from HeliosSDK: HeliosSDK主仓库
Also I can’t find any latest version after this. So can you please guide me where I can clone/download the latest version of SDK ?
I’m sorry, I don’t understand your application scenario. Could you explain to me why you need to use the SDK?
To be honest, at the moment we recommend that customers use firmware for development.
I am just trying to do the things mentioned in QuecDevZone
I need to pack my python modules within the Quecpython firmware
hi
Please provide your email address, We communicate by mail
Hi @Felix.feng-Q ,
I have DM ed my email, Please check your chat
Ok, I have emailed you
