Have I connected to 5G with RM520N-GL?
Hello all,
I have a RM520-GL in a GL.inet GL-M2 adapter. The unit is connected via USB.
I am located in the UK and am using the TalkMobile carrier. They are a virtual carrier using the Vodafone UK infrastructure.
The location I am in can receive 5G signal, I have tested this on an iPhone and on a Huawei H112-370 5G router with the same SIM card. The SIM is on a prepay unlimited data tariff with 5G data.
I am confused as to whether my Quectel unit has successfully connected to 5G network, or is just using LTE. I am getting around 200Mbps down and 40Mbps up, so it could be really good LTE, or slower 5G.
I believe the network I use does use 5G NSA, so I presume this means that I must also be partially using the LTE system to get 5G data.
When I check “servingcell” I see both LTE and 5G data, but when I check AT+QCSQ I only see LTE.
When +QNWPREFCFG: “mode_pref” is set to “AUTO” I get signal, when it is set to “NR5G” the connection never establishes.
Does using “NR5G” setting only work in standalone network and not NSA? Will I always see LTE even though I am actually getting 5G data because of NSA? Or does my Quectel have a problem registering with 5G network? Or perhaps my 5G signal is too weak?
Many thanks!
Here are some diagnostic data from the unit:
AT+GMR
RM520NGLAAR03A04M4G
AT+QGMR
RM520NGLAAR03A04M4G_01.202.01.202
AT+QNWINFO
+QNWINFO: "FDD LTE","23415","LTE BAND 7",2850
+QNWINFO: "TDD NR5G","23415","NR5G BAND 78",628032
AT+QENG="servingcell"
+QENG: "servingcell","NOCONN"
+QENG: "LTE","FDD",234,15,37A61C,448,2850,7,5,5,E00B,-94,-10,-64,20,15,-,-
+QENG: "NR5G-NSA",234,15,806,-93,12,-10,628032,78,7,1
AT+QNWPREFCFG="mode_pref"
+QNWPREFCFG: "mode_pref",AUTO
AT+QNWPREFCFG="nr5g_band"
+QNWPREFCFG: "nr5g_band",1:2:3:5:7:8:12:13:14:18:20:25:26:28:29:30:38:40:41:48:66:70:71:75:76:77:78:79
AT+CREG?
+CREG: 0,1
AT+QENDC
+QENDC: 1,1,0,1,0
AT+COPS?
+COPS: 0,0,"Talkmobile",13
AT+QRSRP
+QRSRP: -104,-95,-32768,-32768,LTE
+QRSRP: -91,-98,-97,-104,NR5G
AT+QCSQ
+QCSQ: "LTE",-67,-94,22,-7
AcT value 13 is E-UTRAN-NR dual connectivity, so that should mean LTE signalling and 5G user data.
Dear @nickds
From the response, device had registered in NSA.
AT+QCSQ is not available with RM520N.
As you mentioned, it is virtual carrier, you can check with them about the speed.
You can also try the latest firmware, I will sent to your email.
Many thanks for your response, from reading into this status it does indeed confirm the 5G data.
