Hardware Setup and Results of Demo Codes
HI All,
New to the Quectel OpenCPU and Forum.
I am using EC200U and SDK LTE01R03A02 working in VS2022 environment and LTE-OPEN EVB kit.
While working with the demo code just try to understand what hardware options / arrangement to be done for checking the particular Application Demo code on LTE-OPEN EVB kit.
LTE-OPEN EVB kit detailed schematic is not available with the manual, anyone can share will be great help to start with.
Thank you in advance.
Hi, friend, This link is the information you need, including the development board user manual and schematic diagram, I hope it will be helpful to you.Best wishes for you.
https://quectel123-my.sharepoint.cn/:u:/g/personal/ae-fae_dom_quectel_com_cn/Ea9ffTCErIROh97Mq8becAYBgRlEHFH5MMzAs6lFGsZTbw?e=fY60oa
Thank you Kelly.li for the resources shared, Is here hardware PWM available on Open_CPU?
hi, pwm is support, Refer to the figure above for the specific pin corresponding pwm function 。
and i also test the pwm_pwt function, it’s ok。
