Hardware design - EC200U-CN + FLASH - NOR Memory IC
Hi all,
This doubt is regarding hardware design.
My previous hardware designer has designed hardware in which he had connected one FLASH - NOR Memory IC to PCM_DIN, PCM_DOUT, PCM_SYNC, PCM_CLK.
But I doubt that it is wrong, my EC200U-CN has firmware version - EC200UCNAAR02A09M08, which does not support any OpenCPU(which can be used to convert PCM to SPI).
So, help me decide that this connection is wrong, FLASH - NOR Memory IC should be connected to MCU if my EC200U-CN has EC200UCNAAR02A09M08 firmware version.
Hi Naresh,
Thank you for contacting us.
  • The EC200U-CN module with firmware EC200UCNAAR02A09M08 does not support OpenCPU, which means you cannot use PCM pins as SPI through software conversion.
  • PCM (Pulse Code Modulation) interface is designed for audio data transfer, not for SPI communication.
  • A NOR Flash memory IC typically requires an SPI interface (pins like MOSI, MISO, CS, CLK), not PCM.
Regards,
Fazrul
Hi Fazrul,
Thank you for the response. Noted on the valuable points.
And I must say that the hardware designed shared in previous post is wrong. And I must connect NOR Flash directly to MCU not Quectel.
Further, I can connect SD-card to module and access it with module only if OpenCPU is supported by the module.
Regards
