Hello everyone, I need help with BC92 modules. I am using termite to connect AWS MQTT with AT command, what should I do? What commands should I use?
BC92 does not support MQTTS and cannot connect to AWS. Please replace the MQTT server that does not support TLS
So will it work on MQTT brokers that do not support TLS?
Yes, BC92 can connect to non-TLS MQTT
However, there is no such mqtt broker, even the mosquitto local broker I founded has it.
