Got error when build kernel in sdx35-es-opensdk
I am working with sdx35 sdk, I am try to build
Copying modules files
Building abl
/home/sdx35-es-opensdk/apps_proc/owrt/src/kernel-5.15/kernel_platform/bootable/bootloader/edk2/QcomModulePkg/build.config.msm.sdxbaagha.common: line 2: /home/sdx35-es-opensdk/apps_proc/owrt/src/kernel-5.15/kernel_platform/bootable/bootloader/edk2/QcomModulePkg/build.config.msm.quectel: No such file or directory
Kernel Build failed. Please check logs above for error…
I don’t know where the file build.config.msm.quectel is come from since can’t search it on the provided packages.
BR
Qui Tran
We cannot find anything from the log.
Please check the
docker/x35_owt/Dockerfile · ESDIOT/bw_linux_init_scripts - 码云 - 开源中国 (gitee.com)
docker/x35_owt/build.sh · ESDIOT/bw_linux_init_scripts - 码云 - 开源中国 (gitee.com)
Yes, I am using a script like yours.
cd apps_proc/owrt/
PWD=pwd
alias croot=“cd $PWD”
export SECTOOLS_PATH=pwd/../../common/sectoolsv2/ext/Linux
source owrt-qti-conf/set_openwrt_env.sh
&& buildconfig RG255CGL_VC RG255CGLABR01A04M4G_OCPU_BETA240821A STD OL debug
&& configure sdx35 mbb debug disable_kernel
&& build_kernel sdx35 debug
&& make V=s -j88 2>&1 | tee build.log
It seems my code does not have file
BR
MEQ
I didn’t see such errors.
Could you try the docker as I did?
