GNSS LG77L Firmware update
Dear Quectel Support Team,
I kindly request your assistance regarding an issue with my LG77L GNSS module.
Module: Quectel LG77L(C)
Flash method:
I used the “MT33xx Firmware download using Flashtool” and successfully flashed:
  • MTK_AllInOne_DA_MT3333.bin
  • LG77LICNR11A01S_GLN.bin
Problem:
After a successful firmware upgrade, the module no longer outputs any NMEA data. /dev/ttyUSB0 shows no data, and the module does not respond to PMTK commands (e.g. PMTK314), regardless of baud rate (tested 9600 / 115200). The device appears as a normal USB serial device in dmesg
Already tested:
  • Multiple baud rates
  • PMTK314 command to enable NMEA
  • Power-cycled the module
Questions:
  1. Is LG77LICNR11A01S_GLN the correct firmware version for the LG77L module?
  2. Is there a way to restore the previous firmware (e.g. $PMTK705,AG3331_AXN5.1.9_MODULE_STD_F5_P3,000C,Quectel-LG77L,1.0*21
  3. How can I factory-reset my development board or the LG77L module?
Thank you!
Hi @SW2020
Q1: Is LG77LICNR11A01S_GLN the correct firmware version for the LG77L module?
A1:I am not sure, LG77L has two version, contain LG77LIC_GLN and LG77L_GLN. Could you tell me which type module you used. LG77LICNR11A01S_GLN is belong LG77LIC_GLN.
Q2 1. Is there a way to restore the previous firmware (e.g. $PMTK705,AG3331_AXN5.1.9_MODULE_STD_F5_P3,000C,Quectel-LG77L,1.021
A2: AG3331 is belong LG77L_GLN, which firmware is LG77LNR11A01S_GLN. I have sent two version firmware to you, please choose the right firmware to upgrade.
Q3: How can I factory-reset my development board or the LG77L module?
A3: $PMTK104
37
Best regards
