GNSS L89 Feedback through UART Not working
I bought “GNSS L89 H” and I am getting data in normal mode.
I want to change mode to get only IRNSS data or GPS etc ..
So I am sending string like “$example_string\r\n” but I am not getting any response back from the h/w.
I tried sending simple “$PING” and I am expecting simple PONG back, I am not even getting that. Can someone please specify the format I should be sending data for change of mode?
Thanks,
Kartick
Hi Kartickjangoo88,
On L89H, you need to send PAIR066 command to change GNSS search mode.
$PAIR066,1,0,0,0,0,0*3B → Search for GPS only
$PAIR066,0,0,0,0,0,1*3B → Search for IRNSS only
Please also check the firmware on your module by sending $PQTMVERNO*58
For example:
I will send you protocol specification for L89H via message.
Best regards.
Hi @Raphael-Q,
Thanks for your response. I have tried what you sent, but it did not work.
I would like to show you the codes and the way I am using them. Can you please see once what’s the issue?
I would mail you the screenshots.
Regards,
Kartick Kumar Ghosh
Hi Kartick,
Did you receive NMEA message from your MCU/program?
Generally, you need to send commands to L89H as strings.
My email: raphael.wu@quectel.com
Best regards.
