Received my new RM502Q-AE, and it appears to be stuck in ‘factory test’ mode. I tried asking for help here, but got none. Appears one needs software costing thousands of dollars to change the mode.
Firmware cannot be downloaded and SHA checksummed for verification.
Sent via email? Straight out of the 80s, just begging for a man in the middle attack. Cannot see any reason to waste any more time on this device, so I’m planning on returning the device and buying Sierra Wireless.
No need to worry about hashes as they are present inside the XML and the exact file size is determined and checked upon flashing in other XML in the zip file
/dev/ttyUSB0, dev/ttyUSB1, dev/ttyUSB2 and dev/cdc-wdm0
All ports show up and I can interact with this using the qmi command line utility but no matter what I do it stays stuck in factory test mode.
