Dear Team,
I have written the below code to get time from the network. but I am not getting any value from the module please validate my code and tell me what mistake I did.
- Function: ATResponse_CLK_Handler
- Description:
This function is used to deal with the response of the AT+CSQ command.
- Parameters:
line:
[in]The address of the string.
len:
[in]The length of the string.
userdata:
[out]Used to transfer the customer's parameter.
- Return:
RIL_ATRSP_SUCCESS, indicates AT executed successfully..
RIL_ATRSP_FAILED, indicates AT executed failed.
RIL_ATRSP_CONTINUE,indicates continue to wait for the response
of the AT command.
- Notes:
1.Can't send any new AT commands in this function.
2.RIL handle the AT response line by line, so this function may
be called multiple times.
static s32 ATResponse_CCLK_Handler(char line, u32 len, void userdata)
ST_CCLK_Reponse CCLK_Reponse = (ST_CCLK_Reponse)userdata;
char *head = Ql_RIL_FindString(line, len, "+CCLK:"); //continue wait
if(head)
Ql_sscanf(head,"%*[^ ]%s,%s,%[^\r\n]",&CCLK_Reponse->Date,&CCLK_Reponse->Time);
return RIL_ATRSP_CONTINUE;
head = Ql_RIL_FindLine(line, len, "OK"); // find <CR><LF>OK<CR><LF>, <CR>OK<CR>£¬<LF>OK<LF>
if(head)
return RIL_ATRSP_SUCCESS;
head = Ql_RIL_FindLine(line, len, "ERROR");// find <CR><LF>ERROR<CR><LF>, <CR>ERROR<CR>£¬<LF>ERROR<LF>
if(head)
return RIL_ATRSP_FAILED;
head = Ql_RIL_FindString(line, len, "+CME ERROR:");//fail
if(head)
return RIL_ATRSP_CONTINUE; //continue wait
- Function: RIL_NW_GetNetworkTime
- Description:
This function gets the network time form the GSM.
- Parameters:
Date:
[out] output buffer for the Date.
Time:
[out] output buffer for the Time.
- Return:
RIL_AT_SUCCESS,send AT successfully.
RIL_AT_FAILED, send AT failed.
RIL_AT_TIMEOUT,send AT timeout.
RIL_AT_BUSY, sending AT.
RIL_AT_INVALID_PARAM, invalid input parameter.
RIL_AT_UNINITIALIZED, RIL is not ready, need to wait for MSG_ID_RIL_READY
and then call Ql_RIL_Initialize to initialize RIL.
s32 RIL_NW_GetNetworkTime(char Date, char Time)
s32 retRes = 0;
char strAT[] = “AT+CCLK?\0”;
ST_CCLK_Reponse pCCLK_Reponse;
Ql_memset(&pCCLK_Reponse,0, sizeof(pCCLK_Reponse));
retRes = Ql_RIL_SendATCmd(strAT,Ql_strlen(strAT), ATResponse_CCLK_Handler,(void)&pCCLK_Reponse,0);
if(RIL_AT_SUCCESS == retRes)
strcpy(Date , pCCLK_Reponse.Date);
strcpy(Time , pCCLK_Reponse.Time);
//*Date = pCCLK_Reponse.Date;
//*Time = pCCLK_Reponse.Time;
return retRes;
