Hello everyone.
I’m sending RMC information to server from mc60 using tcp/ip example provided in SDK.
there is a need to send data in hexadecimal format.
i tried too much to do this using C functions and codding !! but i couldn’t make it .
is there any AT+Command to send the data in hex format ?
MC60 doesn’t support AT+QISENDEX !
i hope Quectel engineers could guide you !
and when it convert the data to hex !?
It dosn’t conflict.
Even your send a ASCII acaracter, application will translate it hex data fisrt then send to UART, The only difference is, in fixed length mode, module will treat 0x1a(ESC), 0x1b(CTRL+Z) as data instead of cancel and terminate.
