Get working lokied EC25-Xxx bought at Ali
There are modems EC25-Xxx bought at Aliexpress or Alibaba for personal use, which are seemed to be locked for Russia.
And the seller either didn’ t know that it is locked or didn’t inform before buying.
As it is only for a personal use, returning of 1 or 2 pieces is quite expensive.
There was an information that if such modems is to downgrade for a firmware, modems can become a bricks
What are ways to get it working ?
hi,
As communicated before, I now understand that this version has restrictions on some regions. Let’s see if we can test it in another region.
Thanks.
The question was and remains is what is to do at the situation ?
And if is to donwgrade the firmware, will not the modem become a brick ?
hi, CpServiceSPb
You can see the following screenshot of the document:
In addition, nv cannot be backed up, but qcn and CEFS can be backed up.
thanks.
Can you send the soft for backing up qcn and CEFS ?
hi,
This backup tool is Qualcomm’s qpst, you need to find it yourself.
Ok. Regarding sent screenshot of some document, what is to do in described situation ?
I don’ t know when this document starts to acting.
But when the modem bought it was locked and th seller didn’ t ask.
hi,
You can try changing the area to test.
Can you tell how ?
And which soft of ?
Can you tell how ?
And which soft of ?
Please, tell how or which soft ?
Or where can I see docs ?
hi,
Please check your email.
Please, tell how or which soft to? Or where can I see docs to? pstasp@gmail.com
Hello! I have the same problem. Please send the materials to my email 4dragunov@gmail.com
Thank you in advance!
