Get Started with EG25-G
Hi there,
I am new to the EG25-G module and I need to integrate it into an embedded board (S32G-VNP-GLDBOX3) equipped with an NXP processor using a PCIe–Mini PCIe adapter. Could you help me understand how to interact with this component through the Linux OS (whose version is: Linux s32g399ardb3 6.6.85-rt53-g6208e1d0d7b5-dirty #1 SMP PREEMPT_RT aarch64 GNU/Linux) running on the board, and also provide links to all the PDF guides I can use?
Quectel just provide the Quectel_UMTS_LTE_5G_Linux_USB_Driver_User_Guide_V3.1.pdf.
You can refer to the
Quectel EC25-A LTE Cat 4 Mini PCIe Module | Raspberry Pi PCIe Database
Using Quectel EC25 on your Raspberry Pi Gateway. Create an EVB Kit for your application – PHAN KHAC HAI
Getting Started with Base HAT + Quectel Modules
