Hi, what is the differentiation between the below PNs
used in this module first production; L86NR02A01S
Now, I found this. i want to use it; L86NR03A01S
Is there any big difference between them?
Br.
Br.
is there any suggest?
Hi Mehmet:
Please refer to the following documents.
when i check this pdf, L86NR02A01S and L86NR03A01S are the same NMEA V4.10 protocol so a replacement can not be a problem. Am i right?
