FOTA UPGRADE using HTTP
I am using M66 module and I want to do FOTA upgrade for the application.
I have tried the example given in FOTA application note and executed the example on M66 as well.
The server link is made properly and used in program in proper way.
Still, I am facing FOTA upgrade failure.
Following is the response of HTTP server and Module communication when FOTA http example was executed:
Dear Parth,
For your issue, pleas help to confirm the following information.
1.module firmware version, the source firmware version and the target firmware version, also need SDK version.
2.Whether you use “Quectel FOTA Package Tool” to generate your needed bin file;
3.Whether your HTTP server is normal and allow to download the files, maybe you can change another server to have a try.
You can refer to the following document to get more information. Thanks! Quectel_OpenCPU_FOTA_Application_Note_V1.0.pdf (629.7 KB)
