I have configured both the LC29H BS module as a base station and the LC29H DA module as a rover device to establish RTK communication. The base station is working with SNIP, and when I connect the rover to receive the data, I noticed that it remains in Float RTK mode and does not switch to Fixed RTK mode. I should mention that the position applied to the base station is not accurate because I haven’t been able to achieve a better value during the survey-in process. I’ve monitored the connection for a considerable amount of time to see if it changes mode, but nothing has happened. What could be the problem? I’ve reviewed the documentation but haven’t found anything that triggers the mode change. Best regards.
These are the commands I have used for both the LC29H BS and LC29H DA:
LC29HBS:
*$PQTMRESTOREPAR 13
$PQTMCFGSVIN,W,1,xxxx,15,0,0,0*26
$PQTMCFGSVIN ,R*26
$PQTMSAVEPAR*5A
$PAIR434,1*24
$PAIR432,0*23
$PAIR432,1*22
$PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
LC29HDA:
$PQTMRESTOREPAR*13
$PQTMCFGRCVRMODE,W,1*2A
$PQTMSAVEPAR*5A
$PAIR062,2,0*3C
$PAIR062,3,0*3D
$PAIR062,5,0*3B
$PQTMCFGNMEADP,W,3,6,2,2,3,2*36
$PQTMVERNO,LC29HDANR11A03S_RSA,2024/03/19,13:55:31*20
Have you changed the convergence time of survey-in of LC29HBS?
The default convergence time of LC29HBS is 43200 times, so it is definitely impossible to output a fixed position in a short time.
You can verify it as follows.
- Send the command “$PQTMCFGSVIN,W,1,300,15,0,0,0*15” to configure the Survey-in mode. After positioning, when the 3D threshold is less than 15 and the cumulative count is 300 times, the Survey-in is completed.
- Send the command “$PQTMSAVEPAR*5A” to save the Survey-in configuration command.
- Send the command “$PQTMCFGMSGRATE,W,PQTMSVINSTATUS,1,1*58” //Open PQTMSVINSTATUS and check the convergence status of Survey-in.
The command format is shown in the figure.
When the <Obs> value is equal to <CfgDur>, it means that Survey-in is completed.
- When Survey-in is completed, you can send the command “$PQTMCFGMSGRATE,W,PQTMSVINSTATUS,0,1*59” to close PQTMSVINSTATUS message.
Hello George.gao, thank you for responding. Yes, I followed the steps you mentioned. In fact, I’ve tested it with different times: 1 hour, 2 hours, and 4 hours, and with a distance of 15m (at the moment, I have the command running on another LC29HBS with 28,800 seconds and 12m). It’s worth mentioning that when executing the survey-in command, I waited for the final result before testing the RTK connection between the devices. The results I got with those times showed that the 4-hour duration allowed the rovers to reach Float mode faster, but they still didn’t manage to enter the fixed mode. Now I will run the calculation again, but I will position the antenna in a different location. The antenna I’ve been working with is outdoors. My goal is to work with centimeter-level GPS, so I need to achieve precise results. Thank you very much
I solved it; apparently, even when outdoors, the position of the antennas wasn’t very good. I changed the position of the base station antenna and obtained a certain value by running the survey-in mode for an hour. I should also mention that I managed to establish a connection between both devices using a TCP server and TCP client, in conjunction with RTKLib (both modules are connected to respective Raspberry Pi Zero 2 units).
My problem now is as follows: I managed to establish RTK Fixed mode, but when I move the rover, it loses this mode and switches to RTK Float. It doesn’t return to Fixed mode until it remains in a stationary position for several minutes and close to the internet it is connected to. I monitored the terminal of the Raspberry Pi to which both modules are connected and observed that the connection between them sends data and stays connected; I did not see any moment when they lost their connection.
Could this problem be due to the quality of the internet signal, the quality of the antenna, or the position set on the base module, considering it was given an hour and a 3D_AccLimit of 15 m? Thanks a lot
Hi @george.gao. For the LC29HBS model, I am using this module and antenna: (https://es.aliexpress.com/item/1005007606687669.html). For the LC29HDA model, I have the following: (aliexpress … /1005006605427126.html). How can I get more information regarding the relevant data? I am currently conducting more tests to observe the performance of Fixed RTK.
Hi @Jorge_Pardo
Please provide your email address and I will send you the relevant information via email.
Hi! I have the same setup as Jorge_Pardo (the same antenna for rover and base station), LC29H easily goes in to Fixed RTK when the rover is stationary but when I move the rover it switches to the Float RTK mode. After some time (few minutes) rover returns to the Fixed RTK mode. Could you help somehow?
same here. does not go to fixed. any advice?
Any suggestions on how to solve this problem? Half a meter accuracy (Float RTK) is unfortuantely useless in my application…
Hi @lucaslab @adoeller
When the base station and the mobile station are static, the mobile station can enter RTK, but can only enter the floating point solution during movement. Therefore, please confirm the following two conditions.
- Make sure that the communication between the base station and the mobile station is stable during movement.
- Make sure that the GNSS antenna signal is not blocked when the mobile station is moved.
@george.gao Thanks. In my case, the communication between the rover and the base station is stable (I connected the RV with the BS by wire), so I have no doubts about its stability. Both antennas have a clear view of the sky throughout my tests. Please clarify: Is it possible to enter RTK mode while the rover is moving?
Hi @lucaslab
When the receiver is moving, it can enter the RTK
