Firmware upgrade request for M95 (MQTT support needed)
Hello Quectel Support Team,
I am working on a project using the Quectel M95 GSM module. My current firmware revision is: M95FAR02A08
When I try to use the MQTT commands (for example, AT+QMTOPEN=?), the module returns +CME ERROR: 100 or ERROR. It seems my current firmware is an older version that does not support the built-in MQTT stack.
Could you please share the following files with me via email or a download link?
  • The latest M95 firmware that supports MQTT AT commands
  • QFlash upgrade tool
  • Latest MQTT Application Note matching the new firmware
  • Firmware upgrade guide
  • Release notes
Thank you in advance for your help!
Testing MQTT on the ConnectLab platform requires version 3.1.1. If the module defaults to V3.1, it needs to be changed to V3.1.1 in order to connect.
the DOC has been sent to your email pls check
I checked my email inbox and spam folder, but I haven’t received the document yet.
Could you please resend it?
Thank you.
Hi @Fyrejue Wallen,
The document you need has been sent to your email, please check it.
The instructions for using Qflash are also included in the Qflsh compressed file
