I downloaded the BG95-M3 USB driver, but after installing it, it did not detect ports REPL for programming. Could you help send me the precise driver and installation instructions for this driver?
(Solution for the missing REPL (Read-Evaluate-Print Loop) port problem that was blocking programming of the module.) -
Instructions for upgrading the BG95-M3 module’s firmware. Kindly supply the relevant documentation.
I require the bg95-m3 firmware version that supports the MQTT communication protocol. How to update the BG95-M3 module’s firmware.
also i am trying to connect with mqtt server using AT COMMANDS. but when ever i tried to mqtt server using at command
i got this response:- +QMTOPEN: 0,4
so can you provide me the mqtt configuration before mqtt connection.
