Hello, AT&T has approved firmware revision “RM520NGLAAR01A07M4G” for module RM520 to be used on its network. Can I please receive a copy?
Your current module version, you can use AT+QGMR query, need to see whether your module and the corresponding version match.
The response for AT+QGMR is:
RM520NGLAAR01A06M4G_01.200.01.200
The firmware has been sent to you through chat, please check.
I’d also like the firmware upgrade. RM520N-GL
Thank You!
@Mike_Hormick
Could you also send me the latest RM520N-GL firmware? AT+QGMR returns: RM520NGLAAR01A06M4G_01.200.01.200. My email is aarioch@aethernet.cc Thanks!
@aarioch The firmware has been sent to you, please note to check
@Alpha The firmware has been sent to you, please note to check
I also need the new firmware as well for this modem current fw is RM520NGLAAR01A06M4G
Dear @Coldcell
I have sent it to you via Message, please check.
Ok got thanks! Will update the modem.
AT+GMR
RM520NGLAAR01A06M4G
Can you please send A07 to me as well? Thank you
@soulnull The firmware has been sent to you, please note to check.
Hello, Can you please send firmware “RM520NGLAAR01A07M4G” to rlynema@yahoo.com..Thanks
@rlynema The new firmware has been sent to you, please note to check.
Can You send new firmware for me please? lintvarevdenis@gmail.com
@KillMistr What firmware version do you need? Please use AT+QGMR to check the specific version number and send it to me. I will give you the matching version.
I need RM520NGLAAR01A07M4G, Now i’m using RM520NGLAAR01A06M4G_01.200.01.200
@KillMistr The new firmware has been sent to you, please check.
