RM500Q-GL
Revision: RM500QGLABR11A06M4G
Regards.
RM500Q-GL
Regards.
Hi,@koreapyj
The latest firmware already send to you via email,pls check.
Hello, looking for latest firmware for RM500Q-GL also. Currently running RM500QGLABR11A05M4G. Many thanks
Hi,@Melomania72
Hey Leon, many thanks for the file however you sent me RM500QGLABR11A06M4G_01.200.01.200. I believe the latest version is RM500QGLABR13A03M4G_01.203.01.203.
Hi,@Melomania72
The firmware version cannot be updated across baselines from R11 to R13. Otherwise, the module may not work. The version I sent to you is the latest version of your firmware baseline.
Thanks.
Hey Leon,can you sent me RM500QGLABR13A03M4G_01.203.01.203. firmware package?r921247204@outlook.com thank you.
Hi,@ViciousCC
The firmware already send to you via email,pls check.
Plesase sent me R13 firmware. Thanks.
Hi @PanTigon
Could you show us your current firmware version and baseline? Much appreciation
Hi @Jonathan.wang
current firmware version: RM500QGLABR13A02M4G_01.200.01.200.
I will send that via email. Please check when you are available.
firmware package?
Dear @Hoang_Vo
Dear @Hoang_Vo
Hello Hoang_Vo, I’m looking for the actual firmware for RM500QGLABR11A06M4G 5G device. Thank you for helping Daniel
i need RM500QGLABR11A06M4G firmware
and qflash new version tool
plz send to email
nemotems2027@gmail.com
I’m in need of the firmware too, as a matter of fact, I’m running on revision: RM500QGLABR11A06M4G, I need to run ‘AT+QOPS’, which using this firmware it doesn’t show me anything, hoping new firmware will alleviate the situation, or If you could help me/ redirect to solve my issue,
Dear @Daniel_Krug
