I need the new firware for L89HA module. Does it support 10Hz refresh rate?
Hi Vipin_Ranka,
I will send you the latest L89HA firmware via message.
You can set 10Hz fix rate by sending $PAIR050,100*22
Best regards.
Thanks @Raphael-Q . It successfully worked. Can you please share the new command set for the same?. I have an outdated one.
Hi Vipin_Ranka,
Sure. I will share you the latest Protocol Specification.
Best regards.
I also have same requirements, please provide me firmware and protocol specifications for 10hz refresh rate
Hi Suryaiyer13,
I will send the latest L89HA firmware to you via message.
Set 10hz refresh rate:
$PAIR050,100*22 → set fix rate to 10hz
$PAIR513*3D → save parameter
Best regards.
