Firmware request for EG25G-QDC507
Need help with the firmware for the module EG25G-QDC507
AT+CVERSION
VERSION: QDC507GLEFM21
Apr 13 2023 19:45:04
Authors: QCT
Thank you in advance.
Hi there,
I have sent an email to your email address. please have a look.
I also need this firmware, pls send it to me.
Hi @damonto ,
Please check your email address. I have sent a follow up email into it.
Thank you and have a nice day~
Hello, I have the same device as well. Could you please send me a copy of the firmware? Thanks.
I have the same EG25G-QDC507 module. I accidentally flashed the wrong firmware, and the device is now unresponsive.
Could you please send me the QDC507GLEFM21 firmware (or a newer version) so I can restore it?
Thank you.
Hi, I need this firmware too. Can you send me the latest EG25GQDC507GLEFM21 firmware?
Hi there,
I have sent a follow up email to your email address. Kindly check.
Hi there,
May I know what FW version you have flashed to your module?
I accidentally flashed the EG25GGCR07A02M1G firmware.
Hi there,
Could you please check with AT command ATI ? I have never heard on this FW version (QDC507GLEFM21) before.
Hi, my EG25G module version is as follows:
AT+CVERSION
Oct 17 2022 14:48:59
Authors: QCT
Could send me the latest version plz? Thank you.
I can’t run ATI right now. The module got bricked during a recovery attempt after I flashed the standard firmware. It’s stuck in a bootloop and doesn’t respond to AT commands. Only 9008 mode is still working.
I had run ATI before flashing the standard firmware, and it matched what others posted. Revision: QDC507GLEFM21
hi @Montia
upon checking, the FW version QDC507GLEFM21 is not developed from Quectel side. You need to contact the supplier for the FW version.
hi Firdaus, could you send me the latest firmware, same as topic? I have the same module.
thanks a lot!
Hi there
Upon checking, the FW version QDC507GLEFM21 is not developed from Quectel side. You need to contact the supplier for the FW version.
Hi Firdaus,
Can you send me the latest firmware for the QDC507GLEFM21?
AT+CVERSION
Jun 20 2024 10:32:11
Authors: QCT
Thanks you!
Hi @hax
I also need this ,thanks
HI @MitoKohaku
