Hi, I need the latest firmware for this modem: EC25ECGAR06A04M1G
Thank you in advance ![]()
Do you also have this as delta update?
Okay, nevermind. Flashing worked fine with qfirehose 1.2, other versions failed with a buffer overflow.
Modem is now happily running with the new firmware ![]()
@herbert.pan-Q Can you also provide me with the root password for this device?
quectel-v : v1.0
quectel-ID : 17445830
hello, here is adb and console passcode, please select the one you need, thanks~
adb passcode:WLk9s9ARtOKV5lh
console passcode: cp7kS7o1SumlJcdWqJfex1
You need to send your request for the firmware Differential upgrade package to support@quectel.com
Please provide the historical version and the version you plan to upgrade
Can you please provide the password for quectel-v : v1.0/ quectel-ID : 93478141?
hello, please check the passcode, thanks~
adb passcode: 6XWPSO1FWCLSjwx
console passcode: qM6DHOIjGuSsBuPI7TN9n/
Hi, is there a new FW version available for this modem (EC25ECGAR06A04M1G)?
Will check and send via email. Please check
